Topping up brake fl...
[Closed] Topping up brake fluid on Hope Brakes
Managed to whack the calliper on my Hope Mono Mini’s this weekend which resulted in me loosing some fluid from the brakes. Now I have found and fixed where the fluid was leaking from, but as I have lost some fluid the lever now has to travel a long way before the brakes kick in.
The question I have is can I now just top the fluid up at the reservoir or do they need a full bleed to get them functioning properly again? If the latter (as I fear) how hard is this to do for someone who is pretty mechanically competent but has never played with hydraulic brakes before?
Posted : 02/03/2009 1:25 pm
Top it up & see how it goes
If you need to bleed, it's fairly simple
Posted : 02/03/2009 1:27 pm
The latest What Moutain Bike has a guide on bleeding brakes, and its a hope setup they demonstrate on.
Posted : 02/03/2009 1:29 pm
 Olly
take the resevoir cap off and push it in from the bottom with a syringe or squeeze bottle IMO.
easy peasy, and no mess.
you will save yourself a whole heap of badaids trouble if you remove the wheel and the pads, however you do it.
if they are in the next room you will struggle to contaminate them.
Posted : 02/03/2009 1:32 pm
