I've had this pump for a couple of years, only used it a couple of times.
I came to use it last night, but found its got some kind of air-lock as even when not attached to valve, when I pull out the handle, when I let go, it sucks the handle back down.
It does this regardless of whether lever is up or down.
I suspect it was fine before I lent it to someone on a group ride ๐
is it kaput?
Posted : 01/03/2014 8:56 am
I har this happen with a pocket rocket. Used it once. Less than 2 months old. Came to use it and it was air locked. Pretty poor really. I should get round to sending it back to wiggle.
Posted : 01/03/2014 9:12 am
Valve stuck shut mine stuck open so soon as you connected it to the tyre the handle shot out. Complete strip and clean is needed.
Posted : 01/03/2014 9:34 am
