Tool recommendation...
[Closed] Tool recommendation....
I’m trying to remove the cartridge bearing from a Hope BSA30 bottom bracket cup. Any tool recommendations will be gratefully received!
Posted : 15/02/2021 8:19 pm
 igm
This isn’t the one I got, but looks identical - even the instruction sheet is the same. To be honest there’s umpteen virtually identical ones.
The one I got is absolutely superb. The only downside is it comes in a cardboard box (with foam inserts) not a plastic case.
Used it on Shimano press fit, where it does the cups the way you’re meant to or if you prefer does the bearing only - your choice but Shimano say no.
Used it on BBrite it remove the bearing.
Haven’t done a Hope but I can see no reason it wouldn’t be just as easy. It’s just another 24x37x7mm bearing isn’t it?
https://www.ebay.co.uk/itm/Bicycle-Bottom-Bracket-Install-Removal-Tools-Kit-for-BB86-BB30-BB92-PF30-UK-G9K2/224161017929?hash=item343109b049:g:OE8AAOSwyaNfZDOd
Edit - sorry it’s a 30 not a 24. It comes with the parts for that too.
Posted : 15/02/2021 8:44 pm
Brilliant, thanks very much
Posted : 16/02/2021 9:16 pm
Bearing pro tools do extractors
Posted : 16/02/2021 11:04 pm
