To grease or not to...
[Closed] To grease or not to grease a square taper bottom bracket axle?
Same as the title really. Got some old Middleburns I'm thinking of fitting and I can't remember wether the axle interface gets greased or not.
Any help appreciated.
Dave
Posted : 09/07/2013 12:10 pm
 mttm
Not. In fact, degrease first.
Posted : 09/07/2013 12:11 pm
Yes, grease.
Edit: this'll be fun ๐Ÿ˜‰
No grease. Just because people do it doesn't mean it's correct. Think stabilisers.
Posted : 09/07/2013 12:12 pm
 Yak
Nooooooo.
Posted : 09/07/2013 12:13 pm
It's one of those things where if you ask a bike mechanic he'll probably say no. If you ask a proper engineer if you shouldn't grease a taper fit, he'll look at you as if you're insane.
Posted : 09/07/2013 12:15 pm
Shimano taper bb do often come with grease already on the axle
But with middle burn arms I'd degrease them to keep things nice and creak free
Don't expect this thread to reach a firm conclusion
Posted : 09/07/2013 12:17 pm
I'm expecting it to be a 5-pager with added insults by 2pm.
Posted : 09/07/2013 12:18 pm
Copper grease?
Cheers,
Jamie
Posted : 09/07/2013 12:19 pm
 Yak
Isn't about not forcing the crank too far onto the taper and knackering the crank?
Posted : 09/07/2013 12:21 pm
A question for retrobike surely?
Posted : 09/07/2013 12:22 pm
Loctite!
Just joking. A very thin layer of grease, and ignore all naysayers.
But as folks have said above - will be fun to watch this thread. Aw
Posted : 09/07/2013 12:23 pm
That is the theory. I've never seen it happen, and talking to quite a few people about it it seems to be an apocryphal rumour dating from the early Cyclotourist cranks which tended to snap everywhere.
This is one of those subjects I file under "Cargo Cult Bike Mechanics" - along with things about the direction of pulling spokes on a wheel, using low speeds with a hole saw when mitering tubes, and always facing bottom bracket shells.
Basically stuff that's done because that's how it's always been done, not because anyone has actually thought about it.
Posted : 09/07/2013 12:26 pm
I've always put a dab of grease on and haven't suffered any damage or cranks falling off.
I have had trouble getting ungreased cranks off though.
 Yak
hmmm- might learn something here.
[awaits some proper maths/fea/ nice graphs etc]
Posted : 09/07/2013 12:29 pm
I spoke to Cliff at Royce about this once he said de-grease, I followed his instructions and never had a problem.
Posted : 09/07/2013 12:32 pm
I've always put a dab of grease on and haven't suffered any damage or cranks falling off. I have had trouble getting ungreased cranks off though.
Exactly as above. Had to cut a set of cranks off a bike recently so much prefer to grease. Might even try copper grease next time
Posted : 09/07/2013 12:36 pm
I did do some tests a long time ago - I'm now trying to remember where I filed it all ๐Ÿ˜‰
The conclusion, I think, was that with good cranks and a good BB, it didn't matter in the slightest. With cheap cast cranks, greasing helped the crank bed onto the axle more consistently.
Posted : 09/07/2013 12:38 pm
 Yak
bencooper - you could have ended the thread there! But cleverly your conclusion allows this to run on.
Old deore hollowtech 1s - are they 'cheap cast' cranks?
Posted : 09/07/2013 12:44 pm
yeeeeeeno
Posted : 09/07/2013 12:52 pm
I tend to say no. based on regular (6-8 months) changes of BB's or chainrings.
however, this changes depending upon when you are.
early 90's, definite no. custom expensive lightweight cranks, cnc-ed to death + greased square taper often led to the crank travelling waay up the taper, either cracking the crank or just hitting the shoulder.
early 00's (or just before...), could probably do so. metal on metal contact needs some form of barrier really and materials and manufacturing was better, less prone to crank failures apart from cheap shyte.
now.... probably not, if you're running square taper you're likely to have a budget set of cranks, which has a higher chance of being cheap soft shyte..maybe.
it also depends on how and where you ride and how well you maintain your bike too, which is probably more critical.
Posted : 09/07/2013 12:54 pm
 gary
Ah, flashbacks to rec.bicycles.tech circa 1990 ๐Ÿ™‚
[url= http://draco.nac.uci.edu/rbfaq/FAQ/8f.11.html ]rec.bicycles FAQ : installing cranks[/url]
(there is a ton of good info on those pages - I'd forgotten all about it!)
Posted : 09/07/2013 12:55 pm
I grease, and always have (left school and went into mechanical engineering), Sheldon Brown greased, Jobst Brandt is also a greaser.
Posted : 09/07/2013 1:20 pm
Grease +1 - based on instinct, not science (but I'm convinced by the link above).
Posted : 09/07/2013 1:26 pm
I thought the rules were:
Splines = grease
No splines = no grease
Posted : 09/07/2013 1:31 pm
I coppaslip. If greasing is going to cause the crank to 'slide'(ie stretch or crack) too far up the taper, then that crank richly deserves the death it finds IMO. I little lubrication to ensure peoper seating and reduce the chance of 'settling' looseness out on a ride. also had cranks bond themselves to bbs before. I imagine this wouldn't be an issue for someone who changes BB or chainrings every 6 months or so.
So maybe the question is: how long are the BB and crank going to stay together?
Posted : 09/07/2013 1:40 pm
There's no correct answer. I go with the following because it makes sense to me.
- new cranks/bb - no grease because the mating surfaces should be flat and smooth and not need any lubrication to either reduce friction or prevent creaking
- used - grease to reduce friction and the risk of creaking once there are marks on the surfaces.
bencooper - Member
We have a winner!
Posted : 09/07/2013 2:40 pm
And coincidentally, my brother has the nickname "Grumpy Dave" on Tower FM in response to the texts he sends in to the morning show.
Posted : 09/07/2013 2:43 pm
In this climate I grease everything that I wish to remove later.
In Oz I don't need to.
Posted : 09/07/2013 2:54 pm
In the spirit compromise how about greasing the drive side and leaving the non-drive side ungreased? Surely that would make everybody happy....
Posted : 09/07/2013 5:05 pm
or alternating per face on the taper in the "loves me, loves me not" format?
Posted : 09/07/2013 5:20 pm
 PJay
I'm with Yak and Mike P on this one. I was under the impression that the advice was to grease Octalink/ISIS as there was a physical stop on the axle, but not to grease square taper as there was a risk of forcing the crank too far up the taper and cracking it (similarly, and for the same reason, I was under the impression that you shouldn't just tighten up a lose square taper crank but pull it first then tighten to the correct torque).
Posted : 09/07/2013 5:27 pm
If I don't grease my (quality) cranks, they have all sorts of settling in problems.
If I grease them, they are fit and forget (middleburn and white industries)
Posted : 09/07/2013 5:28 pm
Copper slip, as its a alloy to steel or Ti inferface.
Now move on nothing to see here ๐Ÿ˜€
Posted : 09/07/2013 5:39 pm
 Sam
Read the piece by Jobst Brandt as linked above by Gary and he will explain both these things.
Grease FTW.
Posted : 09/07/2013 6:56 pm
Just so as you know, the correct way to do it, as they teach bike mechanics for Cytech 2, is NO GREASE.
It's not meant to move. It's meant to stay still. So you don't grease the taper.
It is , however, acceptable to apply a drop of LIGHT oil which will ease assembly but be squeezed out as the taper settles in.
Personally, I've NEVER EVER oiled or greased a taper and NEVER EVER had a problem fitting or removing cranks, probably because I know what I'm doing and have some decent tools though..... ๐Ÿ˜‰
Posted : 09/07/2013 7:01 pm
 Sam
So you never grease threads on assembly either? They are not meant to move.
Posted : 09/07/2013 7:32 pm
 OCB
Yeah, grease ... but; and I dunno where I read the quote, but you only need as much grease as you'd "find on a mechanics finger" (this is clearly from a time before gloves / barrier creams) - which is to say, just a very thin moistening of grease on the faces.
I've always done this and had no negative experiences, including over a couple of seasons of trials riding, which meant frequent BB swaps.
In my experience, just that slither of grease has been fine - enough to facilitate straight-forward installation / extraction, and (but) nothing more.
Possibly just as controversially - I do the same thing when installing headset cups too. ๐Ÿ˜›
Posted : 09/07/2013 7:37 pm
I've always greased them and I'm not a engineer or bike mechanic. Not split one yet.... watch this space. Lol
Posted : 09/07/2013 8:19 pm
LOL Cytech.
Posted : 09/07/2013 8:30 pm
"LOL Cytech" a shroppyshire+1
Posted : 10/07/2013 8:35 am
 JCL
A skim of grease and 25 foot lbs if I remember correctly.
Posted : 10/07/2013 8:45 am
LOL Cytech.
Are you impugning the much-respected industry-wide qualifications system? ๐Ÿ™‚
Posted : 10/07/2013 9:01 am
Go without, if it creaks grease it up.
Posted : 10/07/2013 9:15 am
If you ride your bike in winter, grease it or remove your cranks every so often just in case they seize on.
My opinion is that not greasing is the counsel of perfection and perfectly valid for dry countries or race bikes where things like cranks etc get removed far more often than commuter bikes.
If you use crappy BBs then no need to grease because you're going to be pulling your cranks off frequently. ๐Ÿ™‚
I regard the grease as an insulating layer to prevent electrolytic corrosion between dissimilar metals and not as a lubricant. There may be something better out there, but grease is convenient.
It's probably worth asking the questions:
1. How many have had to cut a crank off that has not been greased?
2. How many have split a crank by using grease?
Posted : 10/07/2013 9:56 am
Shimano silver sauce?
http://www.chainreactioncycles.com/Models.aspx?ModelID=27624
Posted : 10/07/2013 10:05 am
Ocb , i believe that was coined by tullio campagnolo.
More engineer than mechanic.
Its the school of thought i subscribe to anyway and no issues from my mk1 turbines or my rs7s from 2001
Posted : 10/07/2013 10:07 am
epicyclo,
[i]WHAT?!?[/i]
Are you saying [i]it doesn't really matter[/i]?
*gasp*
Posted : 10/07/2013 10:10 am
timbur - Member
Shimano silver sauce?...
I wonder what it's got in it?
Thick oil plus a filler, perchance? ie fancy grease ๐Ÿ™‚
Posted : 10/07/2013 10:34 am
Holy Shit, my voodoo-o-meter just hit 11.
Use grease. Grease enables correct assembly. Whether it moves when assembled is immaterial.
Posted : 10/07/2013 10:56 am
nedrapier - Member
epicyclo,
WHAT?!?
Are you saying it doesn't really matter?
*gasp*
It's actually a roadie rule. They don't believe in greasing their cranks, but slather it on their bums instead. ๐Ÿ™‚
Posted : 10/07/2013 11:15 am
No no no no ๐Ÿ˜†
I have learned through wrenching on and off for the last 23 years that mechanics tend to learn by obtaining information handed down by other mechanics over the years and they then just take on this info as gospel.
You mentioned pulling / trailing spokes too and that's another great example. You have Shimano saying that you have to have the rear pulling spokes on the driveside with this nipples facing in, and Chris King say exactly the opposite IIRC! The are precious few hard facts backed up by scientific evidence in the world of bike mechanics, just history / tradition, and I don't think the likes of Cytech do anything to change this. May as well just learn in a shop from someone with a beard and an attitude problem ๐Ÿ˜€
OK I'm off to build a wheel....shall I use oil, linseed oil, DT Spokefreeze, Wheelsmith Spokeprep.....? ๐Ÿ˜€
Posted : 10/07/2013 3:04 pm
walleater, I used olive oil last time I built a wheel.
To date, I have not died.
Posted : 10/07/2013 3:08 pm
mr monkfinger - what about stems on steerers and bars?
Posted : 10/07/2013 3:10 pm
I used mint flavoured lubricant last time I built a wheel. It has the added advantage of making the air smell nice and fresh for the people riding behind me.
Posted : 10/07/2013 3:11 pm
Steel BB = no grease, Ti BB = thin coating of anti-seize. Has worked for me for 20 years ๐Ÿ™‚
Posted : 10/07/2013 3:18 pm
I don't have a beard!
Posted : 10/07/2013 3:52 pm
Clamping force is parallel, not end on.
Round objects in round clamp, not shaped interface.
Apples and onions, my friend.
so... what about them?
Posted : 11/07/2013 1:37 pm
 Bazz
Was this from the Anne Summers range?
Posted : 11/07/2013 1:47 pm
Did Cytech teach you about the bolt in the end of the BB axle? That's the bit keeping the interface still, not the friction. I'm assuming Cytech also didn't explain to you why the torque in the crank bolt decreases with riding?
So how do you think light oil differs in how it works compared to grease? Or did Cytech not explain that either?
Posted : 11/07/2013 2:02 pm
Grease only one side and report back in 6/12/24 months
Posted : 11/07/2013 2:22 pm
Ah, but 3. how many have found the NDS crank taper absolutely knackered after 6-12 months of writing? It may only be me, but it happens to 70% of my square taper BBs.
Hence why I switched to HTII, relunctantly.
Posted : 11/07/2013 2:33 pm
 OCB
@trail_rat ... Ta! ๐Ÿ˜‰
Posted : 11/07/2013 4:26 pm
