To dish or not to d...
[Closed] To dish or not to dish? Hope pro2/Maverick axle conversion
Bought some wheels for another bike freeing up another set (pro2) but they are for a Maverick fork so lucky enough to get a conversion axle for £10 off the classifieds, slots in nicely no faff. On fitting them to the fork I go for a spin and notice the wheel is all to cock does not feel weird. Will it eat the bearings will I die, hoping to keep the wheelset I have taken off as my winter/grotty tyre set up so just have to swop the cassette when the ice/snow comes.
Dishing I take it is just a case of evenly loosening/tightening they are about 3mm out.
[url= http://farm8.staticflickr.com/7430/11340206053_8199805440_o.jp g" target="_blank">http://farm8.staticflickr.com/7430/11340206053_8199805440_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/nzrich/11340206053/ ]DSCF4179[1][/url] by [url= http://www.flickr.com/people/nzrich/ ]Richard Munro[/url], on Flickr
Posted : 12/12/2013 5:05 pm
Just loosen/tighten a quarter turn on each spoke, assess, then repeat if necessary. Quick and easy!
Posted : 12/12/2013 6:04 pm
Does it make any difference if you fit the axle the opposite way (if possible).
PS Do something about that brake hose. 😉
Posted : 12/12/2013 7:13 pm
As above - go around and loosen/tighten a quarter turn and then check. I think mine needed about a half turn to get it right.
The Pro 2 axle is smooth, unlike the Maverick one, and if you read the MTBR Maverick forum some people have had the axle clips snapping because of movement/slippage.
The solution is to knurl the ends of the Pro 2 axle. If you have (or know someone who does) access to a machine lathe, then it's a 10 minute job.
Posted : 12/12/2013 7:23 pm
The CK axle is also smooth I have three and I've never found it a problem, if the axle clips snap it's more likely due to the user failing to follow the Maverick tension instructions and over-tightening.
Posted : 12/12/2013 9:52 pm
Ethan - an ex-maverick employee who posts on MTBR and sells spares - suggested it when asked by other users who'd had problems. Think he did a bit of measuring and the Hope axle came up very slightly undersized, which the knurling cured.
Anyway, a bit of extra grip on the axle won't hurt.
Posted : 12/12/2013 10:45 pm
Dibbs not a fan of zip ties!
Reference the grip I do have slippage on my King axles very slight but to much for my liking,tempting to over tightening but after a costly snappage I take it easy when clamping up!
Took a full one and a half turns!!!! after a precise true
[url= http://farm8.staticflickr.com/7358/11351421713_bcd99dba93_o.jp g" target="_blank">http://farm8.staticflickr.com/7358/11351421713_bcd99dba93_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/nzrich/11351421713/ ]DSCF4183[1][/url] by [url= http://www.flickr.com/people/nzrich/ ]Richard Munro[/url], on Flickr
Posted : 13/12/2013 12:11 pm
