Titanium frame modi...
[Closed] Titanium frame modifications
Hi,
I have a litespeed ti road frame sitting in my garage that has been sidelined due to the front end being too high even with a 17degree stem. This frame holds a lot of sentimental value to me so I don't want to sell but can't see myself using due to the fit.
Where the top tube meets the headtube, there is a few cm of tube 'spare' between the weld and the headset cup, can anybody recommend a frame builder who may be able to trim a little off this? I would then reface it and fit the headset again, hopefully with a slightly lower stack height. This is all assuming that the headtube is a straight 11/8 all the way down and not hourglassed in any way. Thanks in advance.
Posted : 15/04/2014 7:51 pm
Talk to Enigma.
Posted : 15/04/2014 7:52 pm
Yes, that can be done. Another option would be a custom stem.
Posted : 15/04/2014 7:55 pm
or Ben of course ๐Ÿ™‚
[edit] do you do Ti work Ben?
Posted : 15/04/2014 7:56 pm
I don't weld it (yet) but can hacksaw it as well as the next guy ๐Ÿ˜‰
I do make custom stems, though.
Posted : 15/04/2014 7:58 pm
Custom stems ey? I'm interested, can I email you?
Posted : 15/04/2014 8:19 pm
Sure - ben@kinetics.bike ๐Ÿ˜€
Posted : 15/04/2014 8:21 pm
Ah cheers Ben, I've just seen your website and found the stems on there, I'm running a 14 17deg at the moment so may be keen for a 15. Ill be in touch.
Posted : 15/04/2014 8:27 pm
Can't you just set to it with the headset reamer/ face for a little longer than normal?
Posted : 15/04/2014 8:29 pm
And thanks wwaswas, enigma is a good shout.
Posted : 15/04/2014 8:30 pm
I could do, but I reckon I could get at least a cm off.
