as above, oil seal just wont push in, any tips?
Posted : 21/04/2010 12:43 pm
proper tool works a treat, only £14 ish ...sorry no tips
put a little grease on the outer of the seal (ie inbetween seal and stanchion), or heat seal gently with hair dryer before fitting?
Posted : 21/04/2010 12:48 pm
thank will try that, forks in bits so no time for tool 😀
Posted : 21/04/2010 12:54 pm
Put the seals in the freezer so it shrinks a little, works a treat.
Posted : 21/04/2010 1:09 pm
ah yeah freeze for fitting sorry!
heat for removal 😀
Posted : 21/04/2010 1:58 pm
Thanks! in the freezer they are.
Posted : 21/04/2010 2:23 pm
32mm socket and a little grease.
Posted : 21/04/2010 3:57 pm
Thanks doof_doof it worked a treat.
@ Stuart bought a 32mm socket and used that, still wouldnt budge it till i froze it.
Thanks!
Posted : 21/04/2010 4:07 pm
