Time pedal bearings
[Closed] Time pedal bearings
There is too much play in my Time ATAK XS Carbon pedals. Has anyone any idea if these are serviceable and where the appropriate parts can be had?
Posted : 05/01/2009 12:23 am
assuming there the same as most other Time pedals, undo the end cap, unbolt the nut on the end of the axle (as you left them on the bike - it makes it easier) pull the pedal body off the axle.
Voila access to the bearing, pop down you local bearing supplier and get some more
(these were the cheapest bearings I've had to buy, but don't remember what size they were off-hand)
Posted : 05/01/2009 12:32 am
I had a similar problem on my left hand Time alium pedal I took the end cap off to have a look at bearing, couldnt get bearing out so just put cap back on and tightened it up and problem solved. Turned out the cap had come loose and it acts as some sort of bearing preload (not certain if thats right word) Might not be your problem but its worth a look.
Posted : 05/01/2009 9:48 am
Ta boys- I'll try both of those things.
Posted : 05/01/2009 8:35 pm
