Thule Roof Mounted ...
[Closed] Thule Roof Mounted Cycle Carrier Help
Hi. Hope someone can help me out here. I've recently changed my car. I've always had the thule roof mounted cycle carriers which I love. Sadly, my new car has roof rails that are wider/thicker than the ones on my old car. The clamps on the carriers don't span the roof bars. Does this mean I'll have to change my roof bars - or does anyone know if there's an adaptor that will allow me to use as is?
Any help, much appreciated.
Posted : 19/06/2020 2:08 pm
Will the roofbars take the t track adapter
Posted : 19/06/2020 2:11 pm
By wider, I guess they are some kit of aero/wing design? I've never seen any of these that don't have a slot in for t-track mounting.
Posted : 19/06/2020 2:13 pm
Should be able to change the feet/clamps.
Posted : 19/06/2020 2:15 pm
You will have to change the footpack. There are no adapters.
You may have to change the bars as well depending on the width of the roof.
Thule roofracks have a strong secondhand market so will probably be able to offset the cost.
Posted : 19/06/2020 2:16 pm
Go onto Thules website
You will certainly need new a new footpack. It will also tell you the width of the bars and if you need new ones
Posted : 19/06/2020 2:51 pm
I know it's not clear as they mention rails, but i think they are talking about the carrier/bar interface not the rail/bar interface, as they say "clamps on the carriers don’t span the roof bars". I don't think foot packs are relevant here.
Posted : 19/06/2020 3:11 pm
OP, can you post a picture? There seems to be some confusion as to what your problem actually is.
Posted : 19/06/2020 3:15 pm
What's your old car?
What's your new car?
What model of bar, model of foot pack and model of bike carrier have you got?
Posted : 19/06/2020 3:24 pm
I think the problem is not with the roof bars its the cycle rack. Thule does two kits for attaching the cycle racks to bars...T-rack or clamp. If you've already got a clamp setup and it's too narrow to work with the width of your bars then you might have to go with T-rack if your bars have a T-rack slot...which is actually better.
T-rack adapter....
https://www.thule.com/en-gb/bike-rack/accessories/thule-t-track-adapter-889-1-_-889100
Clamp adapter...
https://www.thule.com/en-gb/bike-rack/accessories/thule-proride-squarebar-adapter-_-889500
Posted : 20/06/2020 9:21 am
