Things that could b...
[Closed] Things that could be nearly perfect except for 1 mistake .
16 Users
For me Madison Flux Lite waterproof jacket . It's light and can fit into a Camelbak , it's waterproof and breathes well , it's nearly perfect , but why oh why did they make it with a hood that you can't remove , it doesn't have anything to roll it up and tie it down with and if you try to pack it down your back and inside the rest of the jacket it is guaranteed to burst out at some point in the ride and become like a sail flapping around behind you . I was considering trying to cut it off but there is no obvious seam to follow and I expect that I would balls it up . Who wears a hood over their helmet anyway . I also have a Flux softshell which has a hood but because it is made with heavier fabric it doesn't cause the same problems .
Posted : 21/07/2019 2:52 pm
Binners.
Posted : 21/07/2019 2:58 pm
You dissapoint me Flashy
Copywright Northwind of this parish
Posted : 21/07/2019 3:50 pm
 tdog
Would ride!
Posted : 21/07/2019 3:54 pm
Here tdog
almost perfetc
Almost perfect
perfect
perfect
Posted : 21/07/2019 3:58 pm
Is it designed to be worn under the helmet? Seen a few like this. Could you see it up or poppers or zip ties?
Also everybike I look at with a frickin press fit bb, instantly ticked off the list.
Posted : 21/07/2019 4:20 pm
5:10 Freerider EPS high.
JUST GUSSET THE FRICKING TONGUE.
Posted : 21/07/2019 5:10 pm
Tongue the gusset, Shirley?
Posted : 21/07/2019 5:18 pm
Dirty boy.
Posted : 21/07/2019 5:19 pm
 csb
Josh. The duo (51g) isn't twice the bar of the single (36g) so it's not perfect.
Posted : 21/07/2019 7:00 pm
Pivot trail 429. Super boost? Really?
Intense frames. With these long seat tubes you are really spoiling it.
Posted : 21/07/2019 7:24 pm
submarined
Member
Also use the same material from the Freerider Element, instead of bloody leather. Basically they're only for cold dry weather. Also they discontinued the Guide Tennie GTX 🙁
Posted : 21/07/2019 7:31 pm
converse hi-tops. Pretty much the perfect sneaker for decades ... except they still haven’t worked out a way to stop the tongue from moving to the side.
Posted : 21/07/2019 8:26 pm
The magura wireless dropper. Sounds ideal except the weird .5 second adjustment period you get on each button press, rather than working like a normal dropper.
Posted : 21/07/2019 8:58 pm
Cannondale Caad 13.
Great until I see BB30a!!!!
Posted : 21/07/2019 9:17 pm
Louise.
Tsk, have a word with yourselves people, 16th post...
Posted : 21/07/2019 9:26 pm
Josh. The duo (51g) isn’t twice the bar of the single (36g) so it’s not perfect.
Its an excellent point also duo =/= trio
Posted : 21/07/2019 9:31 pm
Louise.
Tsk, have a word with yourselves people, 16th post…
Ahhh....Louise...!
Posted : 21/07/2019 9:49 pm
Hard tails. Either take suspension off the front or add it to the back. Weirdos.
Posted : 22/07/2019 7:51 am
Sick Bikes/Rich Energy - nailed the attention getting, just forgot to have a product.
Posted : 22/07/2019 10:15 am
