Thermo forming Bont...
[Closed] Thermo forming Bont shoes
 aP
I've read the instructions on the website but am slightly nervous about putting my shoes in the over [gulp] but the right shoes is pinching slightly at the joint of my little toe ๐Ÿ™
Has anyone done this to a pair before? Is it as easy as they say or is it easy to [i]bugger it up[/i]?
Posted : 25/04/2013 12:02 pm
Very easy, I just made sure I got a separate oven thermometer as it is a low temp that you do them at. Make sure cleats and insoles removed then just bung them in for 20 minutes, might take a couple of tries to get it right.
They are very very stiff and once sorted seem to be a good shoe.
The website says you can do as many times as you like...
Posted : 25/04/2013 12:39 pm
Seemed simple enough...
Not that I use them thou. Didn't find them comfy at all.
Posted : 25/04/2013 1:20 pm
Done mine in the oven twice, first time they were still a bit cramped at the toe.
Even used the wife's hairdryer to soften the toe, then pushed the toe out with a wooden spoon.
Just remember to remove the insoles when you heat them, found out I now have one size 4 insole for a size 8 Bont.
Posted : 25/04/2013 9:04 pm
havent done it with shoes, but decent ice skates are done like this these days, ive done em at home a few times, no problems at all.
er, do i need to point out that a gas oven is a bad idea?
Posted : 25/04/2013 10:12 pm
