The platic tube tha...
[Closed] The platic tube that comes with external bottom brackets
 elma
Do you need to use the platic tube that comes with external bottom brackets you know the one that fits between the two external bearing cases.
Iain
Posted : 12/11/2012 11:23 pm
"Need"? No - it'll work fine without. However, it is there to provide a seal against water entering from the frame and you may find your BB life is shortened without it.
Posted : 12/11/2012 11:24 pm
I drill a hole in my bb shell, pack my bearings with grease and ignore the plastic tube.
I suspect the seal would not be perfect and If yer BB shell is full enough of water for the bearings to be immersed it'd get into the tube anyway (and then may not all drain out again).
Bit like stanchion gaiters IMO
Posted : 12/11/2012 11:34 pm
@druidh: damn it, I did not know that!! Will my £90 hope die early?
Posted : 12/11/2012 11:35 pm
