My first ever build, just need to fit the 1x12 Sram NX groupset, it will probably take me a couple of days between zoom work calls.
Dropper an issue - Crank bros highline won't return automatically but drops fine waiting for Wiggle to answer my email but I suspect they have bigger fish to fry!!
One of the best bikes I’ve had and far better than the Cotic SolarisMax LS.
Wow! How is it better?
Finish- I can't quite believe it.. but this frame has a better finish than the Cotic. The mercury finish on the Cotic just chipped and dulled far too quickly. The orange is marking, but holding up better. I had issues with burs in the ST of the Cotic (chewing up my new dropper) and the BB needing chassing. The cable routing was a mess on the cotic, but is rather well thought out on the O-O.
Ride- This is down to personal taste, but I find it easier to climb and better on singletrack. Sure, it's a little slower on full blown descents, but more than makes up for it on everything else. The frame is also notably lighter, yet just as stiff. It's easier to manual and 'play' around on, but doesn't feel a whole lot less planted.
So, the Cotic was £650 and the O-O £150 (with Headset). It's quite the bargain and I can honestly say that the Cotic was a big dissapointment, and the O-o a very pleasant suprise.
I should caviat this- I have owned 3 Cotics (SolarisMax LS, RocketMAX & Roadrat) and also several O-Os (Inbred, 456 SS & Scandal). I've had various issues with some and others have been perfect. Little disapointed that some spare linkage bits I bought recently from Cotic were inconsistent, even down to two identicle bolts (1 each side) only having loctite on one of them.
On a med scandal and struggling to find the right dropper, could do 180mm one up from saddle height but not enough room in frame. Don't think the 150mm brand X works as it's too long. Think 150mm one up is my only option but obviously not in stock.
Has anyone else rounded off the corners of the front thru-axle?
A combination of being in a rush, ham-fistedness and soft Al means mine cant be undone.
I'll disassemble and square off the rounded corner, but is there a recommended "better" thru-axle at all?
Finish- I can’t quite believe it.. but this frame has a better finish than the Cotic. The mercury finish on the Cotic just chipped and dulled far too quickly. The orange is marking, but holding up better. I had issues with burs in the ST of the Cotic (chewing up my new dropper) and the BB needing chassing. The cable routing was a mess on the cotic, but is rather well thought out on the O-O.
Ride- This is down to personal taste, but I find it easier to climb and better on singletrack. Sure, it’s a little slower on full blown descents, but more than makes up for it on everything else. The frame is also notably lighter, yet just as stiff. It’s easier to manual and ‘play’ around on, but doesn’t feel a whole lot less planted.
So, the Cotic was £650 and the O-O £150 (with Headset). It’s quite the bargain and I can honestly say that the Cotic was a big dissapointment, and the O-o a very pleasant suprise.
I should caviat this- I have owned 3 Cotics (SolarisMax LS, RocketMAX & Roadrat) and also several O-Os (Inbred, 456 SS & Scandal). I’ve had various issues with some and others have been perfect. Little disapointed that some spare linkage bits I bought recently from Cotic were inconsistent, even down to two identicle bolts (1 each side) only having loctite on one of them.
Ta for this feedback, really useful.
I've got a Mt Zoom through axle on another bike that works well.
I bought this frame a few months ago when they were On offer for £150 with seat pin and headset. Just took it out of the box to build it last week using various parts i had in the garage. Using the Specs from PX website i see it requires a boost crankset (53.4mm) and a maximum of a 32T cog. I have used an old XT crankset and a 36T chainring and it all seems to be working fine. Is there a reason why a bigger than 32T chainring should not be used? And why should a regular crankset not work, given that the chain line is perfect at the recommended spacing? Maybe I'm missing something?
Akira, what about the 180 One-up shimmed down by 20mm and 20mm less insertion, would that give you enough room?
Is there a reason why a bigger than 32T chainring should not be used? And why should a regular crankset not work, given that the chain line is perfect at the recommended spacing? Maybe I’m missing something?
I’m surprised you can get a decent chain line with a 36t ring. I’ve got the 32 on, running pretty close to the stay, and it’s central to the cassette.
However, you don’t have to have a Boost chainset. I’m using an old Deore triple chainset with the ring on the middle tabs and it’s fine.
I’m using a non boost GX crank with a 32 ring, loads of clearance and the chain line seems fine.
Ended up with 150mm one up post, the 180mm had too much insert in the seat tube to work. With the bend in the seat tube there wasn't enough usable space. 150mm is fine.
I'm undecided to go for the full build, though not sure if the fork is the best. Wonder if they would upgrade it to the 35.
Also, what size frame would be best suited for 5'11 and does anyone recommend a dropper post an which length?
Sorry for all the questions though thanks in advance!
I'm about 5'8" and running a med with a 150mm one up dropper. Think you'd want large and might fit in a 180mm but you'll need to do some measuring and crunch the numbers. They're not going to change the fork, I went frame only and bought some 130mm Rebas for just over £200, if you did that and sold the old fork for £100+ then that wouldn't be too bad.
Also does anyone recommend a decent dropper post?
I’m 5’11 on medium with 170mm crank bros dropper. I’m all legs though so no issue on insertion.
As mentioned you need to crunch the numbers.
Brand x posts are good value and work very well.
I'm about a 31" inside leg tbf so inbetween I guess
OK, so I decided to keep my Scandal after all and am in the process of building it up. However, I'm having a bit of a nightmare routing the rear brake hose internally.
I've routed the shifter cable internally fine, largely due to the bolt-up guides, but with the hose going through the holes with no guide I just can't get it to line up. I even tried the vacuum cleaner trick to no avail.
Should I have done the brake hose first? Thinking the hose might be being shoved in the wrong direction due to fouling the shifter cable.
I've also got the BB and crankset fitted, might it help if I removed these to guide the hose from the BB area?
Any other ideas? I'm at the end of my tether... If you pardon the pun! 😂
I did hose first - in at the bottom in the open slot with no frame insert and out of the hole at the top with insert. I followed the same principal on them all - in at the narrow slot, out at the point where the insert is. Dead easy - best internal cable runs I've seen.
I ran length of gear outer from top down and out exit on bottom of down tube. Bit of gorilla tape to join gear outer to brake hose and pull it up through without any issue 👍🏻
Decent light and a bent spoke and it wasn't too bad, compared to some road bikes with cabling through the bars and stem as well it was almost pleasant.
I just poked them through and used the natural curve of the hose to poke it down the other end and fish it out with a small screwdriver.
The one I struggled with most was the dropper as I managed to drop the little inserts into the frame!
OK, think I've cracked it tonight, a good torch and an old spoke definitely helped!
Can anyone post up a pic of the headtube of their Scandal front on so I can check I've routed everything correctly?
I see they’ve now spec’d it up with the Rockshox 35s and GX groupset for same price as SLX. Would you go GX or SLX?
Personally I'd go shimano every time. I'm sure others would go sram.
SLX is a solid groupset.
It’s a tough one as it’s a better fork
Looks like there's a titanium scandal incoming too
First proper ride on it at the weekend, it's really pretty good, very stable and goes well, it definitely handles like a long slack big wheeler but that's no surprise. Very impressed with the wtb rangers. My 2011 Rebas are the weak point now for sure. If you have big calves you might catch the seat stays a bit, price to pay for the huge clearance I guess.
Anyone know the screw size for the internal routing covers?! M2 or M2.5? Thanks!
Yeah I've nearly lost mine several times and they seem to fit some of my Allen keys and not others, also very hard to tighten.
Having only ridden mine once due to other commitments and bikes, I might sell it... Large with 120mm xfusion 32 fork, wtb wheels, thomson post, 1x10.
Anybody heard if blokeuptheroad has received his?
^^ Great looking bike there, bigjim!
I got mine in one of the 'seconds' sale at xmas - it was delivered on xmas eve 2019! I almost parted with it before building up but I've finally got it built. Few lockdown purchases and built over a few evenings. Put a smile on my face coming down through the cemetery to work this morning.
[url= https://i.ibb.co/HYKk5CD/P1010457.jp g" target="_blank">https://i.ibb.co/HYKk5CD/P1010457.jp g"/> [/img][/url]
[url= https://i.ibb.co/K95j61C/P1010455.jp g" target="_blank">https://i.ibb.co/K95j61C/P1010455.jp g"/> [/img][/url]
[url= https://i.ibb.co/hRL3jx9/P1010476.jp g" target="_blank">https://i.ibb.co/hRL3jx9/P1010476.jp g"/> [/img][/url]
Has anyone purchased the WTB I29 29er on Formula Boost wheels from PlanetX for their Scandal? Not much detail on the site but I have asked for more info but none appeared - are they Sealed bearings and any idea on their weight?
They are formula hubs so they will be sealed cartridge bearings. I'd guess they would be around 2kg for the wheelset.
Its px, this is why it's cheap! Stack em high, sell em cheap (with little or incorrect info)
You can always return then for a refund if you are brave or you don't mind the risk of px customer service.
Just back for my 3rd ride on mine around the Ballyhoura trail centre in Ireland. It took me a while to get used to how it handles but today I hit a number of Strava segment PBs, up as well as down. Really enjoying it now, only down side is the cheap fork I fitted - Judy Silver, it deserves something a bit more capable.
There's a fair few scandal frames in this pic... They were 125 last time they did one of these sales.
There’s a fair few scandal frames in this pic… They were 125 last time they did one of these sales.
They also sold one frame twice!
I bought one of the larges and instantly regretted it. Anybody want it?
Duckman, I'm interested if it's still available. I've sent you a direct message.
Finally finished the bike for my wife (bought frame in presale, baby born in Feb, sold old 26' bike in May, build up new) and she loved first ride.
[url= https://live.staticflickr.com/65535/50217565056_289ff383fd_c.jp g" target="_blank">https://live.staticflickr.com/65535/50217565056_289ff383fd_c.jp g"/> [/img][/url]
Didn't realise until parts started arriving but colours are her national flag. Any guesses? Build was relatively easy (only second one from me - first being my Scandal v1), bit of sugru in to cover the dropper holes, wheels seem fine for price (PlanetX WTB i29s) and forks were the Rebas mentioned above.
So I managed to bag me a damaged Large Scandal from the weekend sale.
No damage bar a tiny chip on the underside of the chainstay, though Stevie Wonder boxed it in a tracing paper box with more of it on the outside than in... miraculously it hasn't suffered...
...but it ain't got a rear axle (could this be a blessing 😂). So what fits as I'm struggling to find one based on the spec they put up on the website - 148 BOOST axle M12 x 1.75 169mm.
I've got a px rear axle. Pm me if your interested?
I replaced mine with a ktm one. I put a link in this thread a few pages back.
