Oh man, I'm awaiting the drop of a new mountain bike through my letter box, have been for the last couple of weeks.
However I've been crushed to find out that going slightly out of the norm is not without it's own special joy.
Firstly, the rims that were ordered (scrapers) seems to have a troubled journey from Holland and were shy about turning up (apparently). Difficult to build a wheel without em though.
Today, however, I was told that the Reba Boost forks that were ordered turned up as normal instead (only discovered when tried to fit the Boost wheel in them). And that the distributor didn't have any stock. And wouldn't have in stock until mid Nov at the earliest.
Due to the tanking of the pound nobody seems to want to take in stock if they don't know how it'll sell. As far as I can tell the only boost 120mm 29er fork readily available is the Fox Factory 34 Float.... At the increase of a couple hundred quid to the build.... Still, not overly distraught at that particular upgrade though...
So, maybe next week.... sigh.
Buy a Pike and put a shorter air shaft in it?
It's pretty much a custom build via the bike company. Cost of Fox and Pike would end up similar to me so agreed on the Factory 34's. Also looked at x-Fusion but nothing suitable in stock with distributors. Didn't want to break the build and go internet shopping, this'll be my first fully built mtb in probably 20 years.
Will you be riding it by next Friday?
SR: debatable at present. They should get the forks by early next week and the build finished but then they have to ship it to Scotland which everybody knows is a third world country with only farm tracks so will take at least two days... But they know I have plans for that day.
Still have my Solaris (although I'll need to slap back in the 29er wheels).
But hopefully, yeah
How about Manitou Magnum Pro, CRC have stock, 29plus and 27.5plus, 120mm travel and 30% off too at the moment. Just waiting for mine to turn up.
[url= http://www.chainreactioncycles.com/manitou-magnum-pro-forks-15mm-2016/rp-prod134144 ]http://www.chainreactioncycles.com/manitou-magnum-pro-forks-15mm-2016/rp-prod134144[/url]
@bug: as per previous post, this will be my first fully built bike I've bought in knocking on 20 years. With it being a bit out of the norm I decided to leave the hassle of ensuring everything was compatible, etc., to someone else. I've agreed the *upgrade* now so it's also kind of academic.
Thanks for the suggestion though.
There's a 120mm RS1 in the classifieds
What frame did you get?
The new Sherpa.
Very nice frame, let us know how it rides once you build it.
Did you check the new Tarn?
Why go for boost front when the rear isn't?
What's boost?
What's boost?
A new hub standard. 148mm wide instead of the usual 135mm/142mm.
I can kind of see the rationale, but it doesn't mean I have to like it.
Thanks chap
Because my non boost Reba 29er fork doesn't even take a 2.8" NN without loosing paint at the bulge. I want to run up to 3". I'm getting a new bike, might as well go with what seems to be the better option.
Frame is 142 bolt through and website says it takes 3". That's good enough for me. Other than custom, is there Boost rear hardtails out there?
Marin Pine Mountain
No, I was doing the research when my folks were ill (I needed something completely different to take my mind off things). When I decided to go for it (end of June) the new Tarn wasn't 'out there' and I'd already had several decent discussions with Stanton about the build which led me to believe the Sherpa was meeting my requirements....
The situation with my folks (they both passed in July) meant I wasn't too motivated to rehashing my decision (and Dan had reserved a frame for me).
I would be surprised if I don't post a thread (or revive an older one) especially if I get it for my planned outing next Friday. Albeit a bit muted due to the rib situation...
Have X-Fusion McQueen on my plus Hardtail.. Work really well and think they still have stock at uk distributor.
Aren't mcqueens 140mm? Wanted 120mm....
And I've gone with the Factory 34's....
Metalheart - from memory these hardtail frames are boost and fit 650b+: (obviously all 2016 models, not earlier)
Specialized Fuse
Trek Stache
142x12:
DMR Trailstar
Ragley Bigwig
I can't see why anyone wouldn't get a Manitou 650b+ fork, if that's the tyre size you want.
Stick a 120 Yari in there or McQueens (you'll need to convert them down to 120). Both will work well (and better than a Reba). If you buy the McQueens off an actual shop then the 120 conversion is free from the distro. That said neither distro has either Yaris or McQueen HLRs in stock for a few weeks, but they are easily found online.
I got some Boosted 120mm Pikes from Merlin last week, decent price and 29er/650plus compatible so happy I can run a 3.0 tyre in there.
I don't understand why people keep ignoring metalheart when he says he's happy with the fork he's ordered and doesn't want to get something else when the fox meets his requirements. Sounds like a nice build and looking forward to hearing how you get on with the bike once it arrives metalheart! Enjoy
C'mon frood, this is STW, not reading the OP is to be expected...
As is recommending what you've got regardless.
It might help someone else though. I've given up saying thanks, but I've ordered my fork already....
Just the waiting now.
To answer the question of why boost at the front:
[url= https://c4.staticflickr.com/9/8868/28147814891_aefc34a767_z.jp g" target="_blank">https://c4.staticflickr.com/9/8868/28147814891_aefc34a767_z.jp g"/> [/img][/url][url= https://flic.kr/p/JTjUHi ]Nobby Nic 2.8" & Reba RL #1[/url] by [url= https://www.flickr.com/photos/77564901@N06/ ]Metalheart-UK[/url], on Flickr
[url= https://c1.staticflickr.com/9/8693/27953015120_1b73ae1812_z.jp g" target="_blank">https://c1.staticflickr.com/9/8693/27953015120_1b73ae1812_z.jp g"/> [/img][/url][url= https://flic.kr/p/JA7vwy ]Tyre rub[/url] by [url= https://www.flickr.com/photos/77564901@N06/ ]Metalheart-UK[/url], on Flickr
You want to get some Boost forks on there mate.
๐
Just for you Scotroutes:
[url= https://c3.staticflickr.com/6/5819/30009763770_b104866192_c.jp g" target="_blank">https://c3.staticflickr.com/6/5819/30009763770_b104866192_c.jp g"/> [/img][/url][url= https://flic.kr/p/MHRTfb ]Boost....[/url]
After many trials and tribulations...
You can't tease us with that picture, post a few more of the whole bike! I'm looking at getting a Stanton with plus tyres next year so very interested to see how it looks and your opinions on how it rides
@Andy, check my bandwagon thread (or follow the link).
Not had the chance to test it (only got it Tuesday night and its been raining/dark here. Will get out on it sometime in the next week though, I'll post my thoughts no doubt.
Running 2x11 SLX and chain clearance is pretty much non-existant at 26x42 with the 3" Trail Boss. It's either 2.8" or 1x I think.
[quote=metalheart ]Running 2x11 SLX and chain clearance is pretty much non-existant at 26x42 with the 3" Trail Boss.Told ya so.
Tra, la la, la la
Told ya so.
Just as well that I'll never need a gear that low (unless I'm climbing trees)... <we [i]really[/i] need a whistling emoji or whatever you call em>
You'll be callin me fat next...
Chubby.
3" is chubby. 4" is fat ๐
Still, if you need a home for that Trail Boss...
Well, I need to get it properly sealed first...
You have problems sealing on the scrapers?
That's a stunning bike, just found the rest of the pictures! The green frame doesn't look all that good on the website but looks lovely there.
@andy: its a little washed out in the photos due to taking the photos at after 5pm tonight on a grey day. But, yeah, I reckon its pertty nice lookn myself...
This is probably the most representative of it:
[url= https://c2.staticflickr.com/6/5783/30220745641_ba0c286626_c.jp g" target="_blank">https://c2.staticflickr.com/6/5783/30220745641_ba0c286626_c.jp g"/> [/img][/url][url= https://flic.kr/p/N3vdND ]Down tube[/url] by [url= https://www.flickr.com/photos/77564901@N06/ ]Metalheart-UK[/url], on Flickr
[quote=metalheart ]Well, I need to get it properly sealed first...
Only running one tubless at the moment but it was a doddle. WTB rims seem to be fairly "tight" so once the bead is in it's a good fit. I'd try inflating it with a tube first, leave it a couple of days to straighten out, then break the bead at one side, remove the tube, pour in some sealant and pump like fury. Mine went up OK with a standard trackpump.
That green is lovely.
Just been testing my 3 inch nic/ron combo in the remedy with non-boost, tbh there's bugger all spare clearance- sticky mud's going to be iffy. Main thing is- it looks frikkin awesome. If it doesn't work out in the remedy, I might find a hardtail frame for them or I might just give up but it's been fun so far
That green is lovely.Just been testing my 3 inch nic/ron combo in the remedy with non-boost, tbh there's bugger all spare clearance- sticky mud's going to be iffy. Main thing is- it looks frikkin awesome. If it doesn't work out in the remedy, I might find a hardtail frame for them or I might just give up but it's been fun so far
I can thoroughly recommend the Dartmoor Primal Plus if you're after a cheap boost hardtail frame to try. Service from Slam69 was good too.
Just about to order a Dartmoor Primal Plus, what colour did you go for?
