That FOX QR 15mm ti...
[Closed] That FOX QR 15mm tightening nut jobby
how the hell do i do this? i noticed last night that my 15mm QR was moving forward, even though it seemed locked in place.....it basically under vibration pointed further and further forward until eventually the lever was upside down
i removed the screw and the plate and turned the 1-20 dial abit further (it was on 8 to start with) to about 10or11 on the dial....it did nothing and was exactly the same tension?
any ideas on how to fix this, or any ideas what im doing wrong? ive never had to do this before as it was setup fine from new?
why on earth cant it just screw in like the RS 15mm?
Posted : 07/02/2013 1:16 pm
somebody must have had to adjust this?
Posted : 07/02/2013 1:59 pm
all i did with mine was move the little dial thingy around ontill I was happy with the qr position.. took a bit of faffing mind.
Posted : 07/02/2013 2:04 pm
Oscillate - I assume you are doing everything as per this
http://www.ridefox.com/fox_tech_center/owners_manuals/012/Content/Forks/32/InstructionsQR32mm.html
if still persists give Mojo a shout
Posted : 07/02/2013 2:12 pm
thanks tuska - ive not seen that before, i was totally take the axle out and removing the dial thing before - guess thats where ive gone wrong as it says to leave the axle in whilst adjusting
thanks again
Posted : 07/02/2013 2:24 pm
