What driver and battery are you using for the MC-E?
They look good.
Nice brackets as well, where are they from?
Innes
Trout, what's your email address? Got a few questions for ya.
Innes
the driver is a 700 buckpuck I had lying around
battery 14.8 v lithium ion
bracket is a lumicycle one
MBOY-troutie-at-blueyonder-dot-co-dot-uk
This is such a simple build
parts needed are
tesco C cell torch £10 / £12 seems they have been cheaper in some tescos
series wired mce on a 20 mm star
700 ma buckpuck driver or driver of choice.
a small slug of aluminium for the heatsink
Will a cutter lens fit it?
it looks like it does, just checking.
and
I assume you drill and tap the housing for the lumi clamp?
BTW very neat and cheap.
looks spot on.
well done.
Hi Vortex
the cutter lens is a perfect fit will need a bit of silicon for waterproofing
drill and glue in a captive nut for the mount as there is not enough meat to take a tap unless you put a larger slug in and tap that.
which is what I have done for the quad cutter one.
:wink:not really my own idea Smudge did a cutter one before xmas
