tek remedy 9.9 2013...
[Closed] tek remedy 9.9 2013 frame help
hello, purchased the frame. need to know if the main pivot bolt axle is right hand or left hand thread. And also need to know if the to shock mount bolts are left or right hand thread also. please help , don't want to strip the expensive parts..
Posted : 29/02/2016 9:17 pm
unlikely to be left-hand unless you can 'see' a reason in the linkage.
often blue-loctited in tho.
never undone any frame or shock bolts that are left hand.
not done millions tho...
Posted : 29/02/2016 10:37 pm
Seatstay widget/EVO rocker pivots are marked, I think its easier to get them from "inside"? The rest are normal, righty tighty lefty loosy
(Remedy 8 owner)
Posted : 01/03/2016 7:59 am
ok 2013 remedy 9.9 all bolts are standard thread
Posted : 01/03/2016 7:31 pm
