I need my rock shox poplock wire outer casing replacing(worn and bent). Would a standard gear cable outer sheathing do or do I need a specific wire and outer casing? can u get specific rock shox pop lock cable packs?
cheers guys!
Yes gear cables and outers work for me
I used a spare bit of shimano hydraulic sleeve and gaffer tape for the ends. Bodge it like a pro!
cool cheers guys, would any 'size' gear cable be ok, i.e. goodridge as the cable feeds into the fork crown (pike)?
basically if I bouht a length of goodridge gear cable outer - could I just swap it for the stock / damaged rock shox pop lock outer sleeve?
cheers!
It's standard width gear cable. Just use as is. With regards to the outers, use shimano sp-41 and their outers for best performance,, Theirs are sealed with rubber o-rings.
Nokon for me bling bling
