Tapered steerer for...
[Closed] Tapered steerer forks
[#1781467]
I'm eventually going to be after a pair of tapered steerer forks but there doesn't seem to be many options - Fox Floats. What others are there at 120 - 140mm travel? Go on, do my research.
Posted : 08/07/2010 1:49 pm
magura thor's
Posted : 08/07/2010 10:08 pm
Revelations come in tapered but it might be an OEM spec option only. I nearly bought one, is how I know 😳
Still, until I see someone Pepsi Taste Test a tapered and standard steerer fork succesfully at least 4 times out of 5 I'll stick with my old-skool straight stem Revs.
Posted : 08/07/2010 10:11 pm
I can't get my head around this - is it a fork with a conical steerer??
Posted : 08/07/2010 10:34 pm
"is it a fork with a conical steerer?? "
partly, but just between where the top (standard 1 1/8") and bottom (1.5") races of the headset will sit
(So it uses standard 1 1/8" stems)
Posted : 08/07/2010 10:39 pm
Ah, got it - cheers
Posted : 08/07/2010 10:42 pm
2011 Sid 120mm w/ 15mm bolt through, and Revs with 9mm QR/15mm/20mm flavours.
Phew...
*edit* 2011 Reba's do not have a tapered steerer.
Posted : 08/07/2010 11:07 pm
liking the sound of that...
Posted : 09/07/2010 8:40 am
