Tapered forks in a ...
[Closed] Tapered forks in a Carrera Fury
Hi, I've got chance of some great value second hand forks buy but they have a tapered steerer. Is there a headset that'll let them fit my Carrera Fury AM?
Thanks in advance
Will
Posted : 11/03/2016 1:35 pm
Depends on what size of headtube / headset - Googling suggest replacement is:
[url= http://www.fullspeedahead.com/wp-content/uploads/2014/04/005_NO.11N.pdf ]FSA 11N headset[/url] which is an IS44 semi-integrated type - ie. you can fit an external lower headset cup cup for a tapered fork e.g Hope type H bottom cup. Worth checking with your bike shop as your frame may have different specification
Posted : 11/03/2016 1:52 pm
Thanks for the assistance. These headset standards baffle me bit!
Yes the current headset is semi integrated for a 1 1/8 steerer so an external bottom cup would make sense.
Posted : 11/03/2016 1:58 pm
On some of the semi integrated frames theres not enough depth to fit the external cup into the frame.
Posted : 11/03/2016 11:27 pm
[url= http://www.canecreek.com/headset-fit-finder ]Headset fit finder should give you SHIS numbers[/url]
Posted : 12/03/2016 7:19 am
Looking at the headtube, if it is tapered then a tapered fork will fit. If it is straight then it won't fit a tapered fork regardless of which headset you fit.
Posted : 12/03/2016 8:14 am
Andycs - not true. It may have a straight 44mm head tube in which case you can fit a tapered fork no problem. I have done exactly this on my bizango.
Posted : 12/03/2016 11:36 am
Agree, but not in this case. 2015 model fury shows standard headtube.
Posted : 12/03/2016 11:50 am
Looked at a 2015 fury in the local branch this week. It's definitely a 44mm headtube, same as my 2011 one.
The bottom cup recess seemed plenty deep to me when I popped a new headset in last year so an 1.5" external cup should fit fine. It'd probably slacken the head angle up slightly & raise the BB a fraction but I doubt it'd be noticeable.
Posted : 12/03/2016 1:11 pm
[url= https://www.uberbikecomponents.com/view-product/Uberbike-15-Headtube-Tapered-Fork-Headset-Ceramic-Bearings-Gold ]Uberbike 44/44 headset[/url] looks like it'd do the job.
Posted : 12/03/2016 1:16 pm
Ah well, looks like I'm wrong!!
Posted : 12/03/2016 1:39 pm
Cheers chaps!
Posted : 12/03/2016 7:05 pm
