Talk to me about co...
[Closed] Talk to me about cockpit geometry
As it says.
I suffer from neck ache after being in the saddle for about an hour. So if I reduce my stem length and go to narrower bars will this in effect push my body more upright? Possibly reducing the neckache?
Posted : 27/07/2012 11:31 pm
calling it a cockpit is most likely causing your woes ๐Ÿ˜‰
Your guess sounds reasonable tho I am no expert. hi rise bars, saddle forward might help too.
Posted : 27/07/2012 11:34 pm
Are your bars way lower than your saddle? This can cause neck ache as your neck would be in a position similar to sitting on a chair constantly looking at the ceiling.
Posted : 28/07/2012 2:39 pm
Quite about lower. Trying a shorter steeper stem so that might work?
Posted : 28/07/2012 3:46 pm
Something with a good rise on it, got the same issue with my missus on her bike, too stretched out so fitting a shorther stem with a steep rise and shorter bars probably low rise
Posted : 28/07/2012 5:18 pm
higher rise bars an option also?
Oh and can you increase the height of your stem at all? how many stackers above/below?
agree about checking the saddles fore/aft position might even be worth looking at an inline type post (if your current one is layback)....
do any other parts of you ache on longer rides?
Posted : 28/07/2012 6:09 pm
If your bars are quite a lot lower than your seat in an old skool stylee, then a shorter stem would only exacerbate matters, no? Get on all fours and put your hands in varying positions to see.
[tries it and gets weird looks off the kids]
It kind of works. If your back is more upright you have to tip your head further back to see the same point.
What bike is it? Might be time for a more trail style bike with bars and saddle at a more even height.
EDIT - of course raising the stem or bars would help... ๐Ÿ˜ณ
Posted : 28/07/2012 6:37 pm
Gt sensor 1 is the bike.
If my back is more upright so closer to vertical surely I would be looking at the same point with less neck bend?
I'd of thought bringing the stem in would push me back if you lie contributing to a more vertical back?
Posted : 28/07/2012 8:58 pm
Correct; I think he worded it badly, so what he said was the opposite of what he meant.
Posted : 29/07/2012 8:34 am
Ahhhh right. Gonna change the stem, shorter. Might get some narrower bars.
Don't get any aches anywhere else, it is literally just my neck!
Posted : 29/07/2012 8:41 am
