T-129 rear deraille...
[Closed] T-129 rear derailleur
Changing my T129 from SRAM to Shimano and confused by what I need on the rear mech. Running the standard 2x10 it came with but unsure if I need direct mount or not. Don't actually know what direct mount is.
Anyone help?
Posted : 28/08/2015 9:01 pm
Sorry, still 9 speed era on my T129. X9 medium cage, happy as Larry ๐Ÿ˜€
Cheers!
I.
Posted : 28/08/2015 9:09 pm
Any help from the morning crowd?
Posted : 29/08/2015 6:43 am
'Direct mount' is the front mech, surely?
Posted : 29/08/2015 8:19 am
Yep. Direct mount is for the front. If you want to run a shimano rear mech you will have to also change the front shifter. Then you are into issues as the T129 runs an integrated bar mount with SRAM brakes/shifter so you will need to find some way to attach it all to the bars.
Posted : 29/08/2015 9:05 am
There is direct mount for the rear as well, Shimano proprietary. By default the derailleur is compatible with a normal hanger; by removing the last knuckle it can be mounted "directly" on a swept-back hanger. You shouldn't care about this unless you already have the Shimano DM hanger and want to run a SRAM derailleur, in which case it won't work.
http://www.pinkbike.com/news/Shimano-Officially-Introduces-Direct-Mount-Rear-Derailleurs.html
For mating Shimano shifters with SRAM brakes you should be able to use an adapter, although it doesn't look like one is available for I-Spec II yet.
http://problemsolversbike.com/products/mismatch_adapters
http://trickstuff.de/de/products/clapton_KL.php
Posted : 29/08/2015 9:11 am
Whole lot is going Shimano. Hate Avid brakes and not getting on with SRAM shifters.
Posted : 29/08/2015 2:44 pm
