Switching Xt brakes...
[Closed] Switching Xt brakes around
My mates brought a Radon bike and the brakes are euro style not english style. It is simply a case of unscrewing the hose from the lever and swapping them around? Will they need a bleed afterwards?
Posted : 09/05/2015 10:58 am
Should be ok, just be careful!!
Posted : 09/05/2015 11:02 am
If you leave the revisoir caps on you'll loose virtually no oil. Once re connected they usually just need a couple of pumps on the lever and that's it
Posted : 09/05/2015 11:04 am
Easier with two people. One person holds the first hose steady while the other removes the second. Then just swap them carefully. Should be fine.
Posted : 09/05/2015 11:07 am
 jimw
See this, explains how to work on hoses without bleeding. Disregard the bits about shortening, its the start and finish points that are relevant
http://www.epicbleedsolutions.com/blog/shorten-shimano-hoses-without-bleeding/
Posted : 09/05/2015 11:10 am
And whatever you do don't accidently touch the levers! ๐Ÿ˜ณ
Posted : 09/05/2015 11:48 am
It's a fairly normal tip to remove wheel and give the lever a pump or two to expose pistons without ejecting, leave caps in place, swap hoses, open caps then push pistons back. I assume this is what the Epic video is showing.
It can go wrong, you may need to bleed especially if there is any hidden air lurking already, but you've got a pretty good chance of getting away with it.
Just have everything to hand and don't waste any time once the hoses are opened. And don't let the open ends of the hoses point anywhere other than straight up.
Posted : 09/05/2015 11:58 am
Thanks all. If my mates brakes fail and he dies I'm going to sue you all
Posted : 09/05/2015 1:19 pm
