Swift - creaky EBB
[Closed] Swift - creaky EBB
been riding a swift with the Phil Wood EBB for about 6 months (ace bike)
i've taken it out and re-greased quite a few times because of annoying creaking. the set screws are as tight as i dare. i wash it carefully and i confess i am a bit of a fair weather rider so it hasn't really had much muck in there!
so far i have just used the bog-standard finish line grease (the white non-sticky stuff) which i apply to the outside of the ebb, the set screws, and also the threads of the BB
is this the norm with EBB's or should i try something else? have seen talk of copper slip and (bizarrely) PTFE tape...
Posted : 24/10/2010 12:24 pm
currently running a 1x9 setup so i don't need it to tension the chain, so i have it in the 6 o clock position
Posted : 24/10/2010 12:26 pm
Never had a peep out of mine, i dont do the screws up tight tho as they dont need to be, maybe thats the root of your problem?
Posted : 24/10/2010 12:27 pm
Copper slip sorted my creaky EBB. Though I've got a niner, which is a different design to the phil wood jobs.
Posted : 24/10/2010 12:33 pm
cheers for the replies. just applied copper slip, we'll see how long it lasts!
Posted : 24/10/2010 1:01 pm
I went though BB creaks with mine and immediately blamed the EBB. I took out the EBB and greased it, fiddled round with how tight I did up the screws... no effect.
In the end, it was the threads of my BB cups just like it would have been on a normal BB shell. If it's still creaking, grease your BB threads. I use copper grease, but normal grease will probably do.
To be fair to it, when mine did start creaking, I did think back to standing in a river to fill my water bottles while it flowed at about BB height ๐Ÿ˜ณ
Posted : 24/10/2010 2:37 pm
