Swapping out a drop...
Swapping out a dropper post from a steel frame to a carbon
[#13536594]
I'm taking a dropper post out of a steel frame and plan to use it in a carbon one and it has some light surface rust. I"ve wiped most of it off with a clean cloth. Is this OK to insert into a carbon frame without doing anythig more than adding friction paste?
Posted : 06/08/2026 3:58 pm
Is it rust from the steel frame just sat on the post surface or corrosion of the aluminium post?
Posted : 06/08/2026 4:23 pm
Rust from the steel frame just sat on the post in so far as I can tell
Posted : 06/08/2026 4:41 pm
Then yes just clean it off and insert with friction paste.
Posted : 06/08/2026 4:52 pm
