Are the remotes interchangeable? Just the unscrew/screw attachment for both?
Posted : 17/08/2015 12:04 pm
Yes to both.
Posted : 17/08/2015 12:27 pm
Not all are. I think new ones are interchangeable but the older one move less fluid. My old one with a silver barrel adjuster wouldn't work properly on a new Stealth.
Posted : 17/08/2015 12:30 pm
You can get them to work. It's a bit of faff though. If using a silver adjuster with a stealth you can get more fluid into it by taking out the staple that holds the button in place, removing the button, adding a few drops of fluid directly then replacing it. Mine works fine after this, but I accept bleeding it may cause problems and mean I have to do it again.
Posted : 17/08/2015 2:45 pm
