Surly hub bearings
[Closed] Surly hub bearings
They seem to use a non-standard size, 7901.
I've had to replace the rear hub bearings before, but it wasn't that size and I can't remember which size it was. I don't have the option of looking at the current bearings.
Can anyone tell me which other size is compatible? I know Surly say they wont last as long, but I had longer life from the replacements than the originals.
Posted : 07/12/2010 11:48 am
which hub?
Posted : 07/12/2010 12:00 pm
Rear disc, but I think they all use the same bearings?
Posted : 07/12/2010 12:03 pm
yeah, 7901, it says here http://www.surlybikes.com/blog/spew/spew_8_spoke_calculation/ just going to whip the locknuts off a hub to check tho...
yeah, that's right - 7901RS
Posted : 07/12/2010 12:10 pm
I'm looking for the alternative size to 7901, because they are expensive & hard to get hold of.
Posted : 07/12/2010 12:15 pm
Hey, as far as I know it's the same size as a 6901 2rs 12x24x6 but angular contact with greater side impact and side loading properties.
http://www.skf.com/portal/skf/home/products?maincatalogue=1&lang=en&newlink=1_3_1
http://www.vxb.com/page/bearings/PROD/Kit8221
Doesn't really make that much difference and a lot of companies have run 6901 bearings and it's been fine.
I have some jap bearings at good prices, why not check the specs of the bearing if I'm right, give me a shout.
Posted : 07/12/2010 12:18 pm
s'pose £8 each is a bit expensive but from my experience they do last well.
we have them if you can't find them locally.
Posted : 07/12/2010 12:21 pm
6901 2rs £6.50 each fully weather proofed japanese bearings. I would put them up against any bearings in the industry.
Posted : 07/12/2010 12:23 pm
6901 looks right, thanks 🙂
Posted : 07/12/2010 12:26 pm
No problem, how long have the bearings that are in their lasted and do they have a brand?
Lastly don't buy cheapo rubbish bearings, they don't last very long and you will simply need to change them all the time, as in every 6 months.
http://www.singletrackworld.com/forum/topic/wheel-bearings-1
I have bearings in that size coming into the country in a week or so, they work great in pivot points, however I need to test them in hubs, if you can wait I will give you some to test for free, if you can let me know how you get on with them I would really appreciate it.
Upto you, but the offer is open.
Posted : 07/12/2010 12:33 pm
If you're still looking for someone to try these bearings out I need some for a Surly hub.
Feel free to send me a pair and I'll tell you how long they last.
My addys in my profile.
Posted : 25/01/2011 9:41 pm
