Has anyone found any end caps to convert a V6 non boost rear hub to boost. Or is it as simple as fitting a 3mm spacer each side ?
You need a kit like
Cheers yeah I was thinking that might be the only way to do it. Just wondered if anyone had found any compatability with the Novatech hubs.
V6 are all made in house so I doubt there will be any cross compatibility with other hub brands
Superstar sell the kit themselves, should be in the hub spares section online. I have used it on my lads bike. Just need to take care when removing the wheel not to lose the spacers.
Unfortunately the adapters that SS sell are specific to boost /Non boost hubs. Ie you can't fit boost adapters to a non boost hub.
Just email superstar, they usually respond quickly.
