Superstar switch hu...
[Closed] Superstar switch hubs instructions
[#7313902]
Either my Google-Fu has evaporated, or all the links to Switch hub instructions I can find online are dead. I need to put new bearings in some original Switch hubs. Has anybody got any working links to online instructions, or the instructions in a PDF they can email me please? Failing that a step by step guide?
I've managed to remove the threaded cap from the NDS, but don't know what I need to replicate this on the driveside ie how to immobilise the axle.
Edit. SSC aren't answering the phone this morning......
Posted : 07/09/2015 10:48 am
YGM!
Posted : 07/09/2015 11:07 am
Thanks steezysix
Posted : 07/09/2015 11:42 am
Would you mind sharing the info? Would be handy for future fiddling. 🙂
Posted : 07/09/2015 12:27 pm
I could really use a copy as well if anyone is able to share them. Also, do you know what bearings I need? I've been hunting all over the place for this information too.
Posted : 07/09/2015 12:41 pm
6802 front, 6902 rear.
The front needs two and the rear needs four, two in the hub, two in the freehub.
emailed you both with PDFs
Posted : 07/09/2015 12:50 pm
@steezysix
YGM back...... The NDS end cap screws off with cone spanner flats, the driveside had 17mm spanner flats, and neither end cap will take a 5mm wrench. I can remove the NDS, but cannot immobilise the axle to remove the driveside end cap. Does the axle take an 11mm hex?
Posted : 07/09/2015 12:53 pm
I presume you are talking about the rear hub? What axle do you have?
If standard QR I think you need 5mm allen keys in both sides to undo. If through axle then use cone spanners.
I think the drive size cap is attached to the axle, so take the non drive side cap off and then tap the axle through the hub with a hammer and screwdriver.
Posted : 07/09/2015 2:11 pm
Ah, that would make sense. They are QR endcaps, but despite all instructions to the contrary, these don't take a 5mm hex- I've tried.
If I try to knock the axle through, it will take the freehub with it...is that right??
Posted : 07/09/2015 3:31 pm
Yep, the freehub body came out with the axle.
Posted : 07/09/2015 3:32 pm
Oh, and sorry for the misinformation above. [b]Front bearings are 6804, [/b]not 6802.
Posted : 07/09/2015 3:36 pm
For any one else. I've uploaded the PDF's that Sueprstar gave me here:
http://1drv.ms/1OrAdZ8
There is a listing of bearing sizes for hubs and some very simple instructions for front and rear switch hub.
Posted : 07/09/2015 3:59 pm
Thanks, that's a great help :D.
Posted : 07/09/2015 5:10 pm
Cheers guys.
Posted : 07/09/2015 5:21 pm
