Superstar Switch hu...
[Closed] Superstar Switch hubs (f) - bearing swap.
Sure there was a thread about this a while ago, but can't find anything using the search.
Swapped out the rear wheel bearings on my switch/arch wheelset fairly easily, but can't get the front ones out. End caps off and instructions just say to drift the front ones out but can't do it for the life of me. Can't seem to get enough purchase on the bearings to get them to move.
Is there some knack to it that I'm missing?
Posted : 11/04/2014 9:42 pm
If its anything like a Hope Hub I normally use an alloy drift/punch but it needs to have a good edge on it and not blunt, Just place the punch inside and try to push the inner spacer over slightly at the same time, swap side occasionally and they should both bosh out no problem.
Are there any cir clips on the outer edges? check first, i think the switch hubs have rubber coated ones on the rears, but I'm not sure about the fronts. hth
Posted : 11/04/2014 9:47 pm
Takes a while and a drift with a nice defined flat edge. And plenty of ****ting with a big hammer.
Posted : 11/04/2014 9:48 pm
Gah, too slow. What he said!
What size drift do you need?
Posted : 11/04/2014 10:07 pm
 rsl1
It's quite hard to get between the axle and bearing, I have a flat head screwed offset into a piece of rod to get it started off. Also may be obvious but first time I did it took me a while to realise my brake disc was stopping the bearing from moving
Posted : 11/04/2014 11:23 pm
