Superstar Switch hu...
[Closed] Superstar Switch hub bearing change manual
I know i've seen a link posted somewhere to the manual for changing bearings / freehub on a switch rear hub, but can't find it after at least 2 attempts at searching. I think it was on the novatech site but cant find it on there either.
Anyone know it? 😕
Posted : 07/12/2011 2:25 pm
I can email them to you if you want....
Posted : 07/12/2011 2:49 pm
That'd be grand. Email now in profile.
Cheers. 😀
Posted : 07/12/2011 2:54 pm
I think they are Novatec B881SB / D882SB hubs. I haven't got them myself but may be soon so can't confirm the links below are the right ones but have a look.
http://www.novatec.com.tw/novatec/english/p_show.php?sid=280
http://issuu.com/novatecwheels/docs
http://www.youtube.com/watch?v=e_w7oOHxeJY
http://www.youtube.com/watch?v=yxVxs7hoXrc
http://www.youtube.com/watch?v=2udGN6xQ5aU
Also it looks like one of the bearing is behind the freehub engagement ring so you'll also need a freehub ring nut removal tool, [i]if[/i] it's the same as the DT ones then it'll be £50!!
http://www.fawkes-cycles.co.uk/3496/products/DT-Swiss-Ring-Nut-Inst-240s-FR.aspx?utm_source=Froogle&utm_medium=PriceComp&utm_term=Froogle&utm_content=None&utm_campaign=PriceComp1
Posted : 07/12/2011 3:21 pm
It looks like the Novatec freehub ratchet ring tools are 24 tooth and the DT Swiss ones are 26 tooth so you'll need to make your own, take it to a LBS or sent it back to Superstar!
http://issuu.com/novatec.manuals/docs/remove_ratchet_ring
Posted : 07/12/2011 4:40 pm
 al
The drive side bearing isn't "behind" the ratchet ring, it slides right through it. No need to remove the ratchet ring at all.
Posted : 29/02/2012 10:38 am
