Superstar 10mm QR w...
[Closed] Superstar 10mm QR won't fit in dropouts
Building up my new slackline frame last night i offered up my rear wheel and the 10mm superstar thru axle /qr solid lump of metal is too big to fit in the dropout.
I can get the conversion kit to normal qr easy enough and offering up a different rear wheel with regular qr seemed to fit right
Should i be worried or is it just a small dropout on this frame?
Posted : 10/03/2015 11:38 am
Standard dropouts/axles are 9mm.
Posted : 10/03/2015 11:45 am
 cdoc
Double check that there is no damage or pinching of the dropout gap. Bashed mine once and it closed it up slightly and gave me the same problem.
If it is fine and just a bit on the tight side there should be little issue in taking a small file to it.
As said, 9mm is the standard although many frames will take a 10mm with no editing
Posted : 10/03/2015 11:46 am
Nope front axle/ dropout is 9mm rear is 10mm
Posted : 10/03/2015 11:47 am
As cdoc said. Try pushing the QR through the dropouts from the side, not the top. If it goes through you'll need to open the slot up a tad.
Posted : 10/03/2015 11:49 am
It didn't go in from the side either. Got a feeling it's taken a knock somewhere as the plastic spacer thingy was difficult to remove when i was unpacking the frame.
bollocks
Posted : 10/03/2015 11:50 am
Yep should fit I have a Hadley 10mm thru in my Slackline, something not right.
Posted : 10/03/2015 11:52 am
I've emailed Dan Stanton about it.
Dammit, i'm off down to the surrey hills in a week and wanted to "shred the gnarr" or whathaveyou on it
feeling glum now
Posted : 10/03/2015 12:00 pm
is it too tight on both sides or just one?
Paint a bit too thick? Take a file gently to it?
(after discussing with the retailer first, of course)
Posted : 10/03/2015 12:16 pm
It could just be paint. Can you slide it in from the side?
Posted : 10/03/2015 12:17 pm
It's too tight on both sides. It is thick enamelled paint which is in the dropouts as well. I did think about a file, but was thinking it was odd it didn't fit from the off
Posted : 10/03/2015 12:20 pm
I bought a road bike, built it up and last job was to fit the front wheel.
It wouldn't fit and upon closer inspection, it had obviously been dropped off the van at some point and landed on the forks, crushing the dropouts slightly. I did wonder why the front spacer came out in a cracked mess.
Can you see any hairline cracking in the paint that might suggest it's been bent after manufacture?
Mine had several hairline cracks all the way round and you could feel a slight bulge in the metal around the 'pinch point' of the squashed area. Sent it back and got another one.
Posted : 10/03/2015 12:28 pm
There's a very high probability it's just paint.
Posted : 10/03/2015 12:30 pm
@stumpy - no bulges, no cracks. I had a good look over the frame before i started building it up.
I do get the feeling it's paint which is a good thick coat over the bike
Posted : 10/03/2015 12:36 pm
You would expect paint to accumulate over areas like the edges of a drop out so probably just that.
Posted : 10/03/2015 12:40 pm
 cdoc
A bit of fine wet and dry taped to a steel ruler is great for removing the excess paint on bits like that. A bit less aggressive than a file.
Posted : 10/03/2015 12:50 pm
 igm
Dremel with sanding wheel
Posted : 10/03/2015 12:54 pm
It's not a 12mm axle is it? ๐Ÿ™‚
Posted : 10/03/2015 4:44 pm
