Superlight bottom b...
[Closed] Superlight bottom bracket axle length?
One of the more exciting requests, have got a 2002 santa cruz superlight which have retrofitted some coda cranks to. square taper bottom bracket and i can't get the the big ring to work without bad chain rub using a 103mm axle. So does some one know/remember the correct axle length?
has me a bit confused. not sure if it's the cranks or bottom bracket at fault.
Any advice/help gratefully received thanks.
Posted : 08/05/2010 7:43 pm
The bb size is related to the crankset & bb width iirc. So the issue is probably related to the bb fitted. The middle ring is 'normally' around 47.5 mm from the center of the bb
http://www.sheldonbrown.com/chainline.html
Posted : 08/05/2010 8:24 pm
thanks i'll check that measurement out tomorrow when it light ( bikes in the garden ) then post the results.
thank you for your advice.
ricky
Posted : 08/05/2010 11:10 pm
