Stupid geometry que...
[Closed] Stupid geometry question
I am looking for a trail dual suspension bike. I notice that a lot come with straight through dropper posts and short stems. I have always run a layback post, just seems to work as I am long-backed. Can I just run a longer stem to 'correct' the position or should I size up to stretch the reach. The bike I am interested in, I will not be able to test ride first.
Posted : 31/07/2017 9:33 am
Longer stem will alter the handling. Layback posts are for people who bought a frame that was too small ๐Ÿ˜‰
Longer TT with similar stand over is quite normal these days, have a look at those numbers first. I couldn't try the bike I was getting but found something I had slung a leg over with very similar numbers - or a shout out on here for somebody near you that has one
Posted : 31/07/2017 9:45 am
Bike fitting sequence is always: saddle - pedals - bars. Most importantly is saddle height and pedal position - the amount of layback achieved either by seattube angle + saddle layback and is mainly a function of femur length. MTBs have gravitated towards non-layback posts because of steeper seattube angles and droppers. If your seat is too far forward and you fit a longer stem, it'll throw your weight forward - possibly losing rear wheel traction and more front wheel wash-out - you'll probably generate less power too as you can't engage the quads as effectively. Go for the frame that puts your bum in the right place and adjust the reach / stem / bars accordingly.
Posted : 31/07/2017 10:12 am
f you're getting a bike with the latest geometry you'll probably have to adapt your riding style to get the most out of it.
I too have a long back in comparison to my legs. I've recently gone to a shorter stem, less layback seatpost on the same frame. It took a bit of getting used to but now it feels great. Much more capable.
Posted : 31/07/2017 10:25 am
Thanks for the replies. I will get a cheap post and play around with the position. What I am taking from this is to size up and trade off on stand-over
Posted : 31/07/2017 1:02 pm
do you have to trade off standover? What are the actual measurements? and how do they compare to what you ride now?
Posted : 31/07/2017 1:03 pm
Only a 20mm difference on the stand-over, and the reach goes from 455mm to 485mm, TT from 621mm to 654mm.
Posted : 31/07/2017 1:07 pm
important one is how that compares to what you ride now, is that 20mm a lot?Leave you close?
Posted : 31/07/2017 1:09 pm
Based on the numbers I would go from having about 100mm of clearance to 80mm..
Posted : 31/07/2017 1:11 pm
sounds resonable to me though can you find something with similar to check out?Whats the bike?
Posted : 31/07/2017 1:14 pm
Kona Hei Hei DL, but am open to something similar
Posted : 31/07/2017 1:17 pm
I don't consider standover an issue, particularly on an MTB. Why would I need to stand over my bike?
Posted : 31/07/2017 1:24 pm
Stand over is always measured at a point that you can't actually get to because the nose of the saddle is poking you in the back but I get the idea that it's useful to be as low as possible.
How tall are you/what's your inside leg and what does you current bike geo look like compared to the one you're looking at? It's all meaningless without pics and /or numbers.
Modern geometry is pushing you forward relative to the pedals so you don't wheelie so easy going up hill and the front is raked out to compensate with a short stem so it doesn't handle like a supertanker and wide bars to give more leverage/slow things down a bit/ get you in a better body position. If you're on an old school short TT bike with lay back seat post and long stem it'll obviously be a completely different (but probably infinitely better) bike.
Posted : 31/07/2017 3:05 pm
Again, thanks for the responses, I think I will try to get a test ride of a similar bike
Posted : 31/07/2017 3:35 pm
You've said that before, and I know there's a winky smiley there but it simply isn't true and I do wish you'd stop saying it in case it mis-leads anyone looking for advice.
A layback post should not be used to 'correct reach' though, but there are many reasons why you might need/want one to get your bum and legs in the right place relative to the bottom bracket.
Posted : 31/07/2017 5:46 pm
