Stupid fox RLC adju...
[Closed] Stupid fox RLC adjuster knob
Is there anyway of stopping the compression dial turning when you move the lockout knob?
The compression dial seems to be spring-loaded against the bottom of the lockout knob so it always moves out of position whenever I move the lockout.
It's all clean, so that's not the problem. Is it really that crappy a design?
Posted : 06/12/2010 8:26 pm
If it's Fox, it's probably a crappy design. Fashionable though.
Posted : 06/12/2010 8:34 pm
No-one else have this problem?
Posted : 07/12/2010 12:15 pm
does it not move back with the lock-out lever as well?
Posted : 07/12/2010 12:24 pm
yeah i did on 09 ones' where the bloody rebound, compression and lockout were all on the same top knobs ๐Ÿ™
thought the new 10 ones onwards had the rebound on the bottom, and just lock out and compression ontop? Surely still not an issue? i thought thats why they changed the 10 ones....
if they are 09's then i feel your pain, as my rebound and compression used to move every time i locked out ๐Ÿ™
shit design, you can unscrew the little grub screws to give a good clean, which helps until mud/sand/grit etc gets back in (ususally after 1 ride) and your back to the same scenario again...
They are 09 ones, but I don't see how the new design is any help. the rebound isn't the problem. It's the compression being moved by the lockout.
๐Ÿ‘ฟ
Cleaning doesn't help - it's totally clean now and still has the same problem.
Basically the friction between the lockout and compression dials is higher than that between the compression dial and it's indents.
Posted : 07/12/2010 12:28 pm
Yes have sane issue too; have stripped , cleaned and lightly oiled but compression dial still shifts a notch or so, both ways, when either engaging or disengaging lockout, think it is an 09 model. I just live with it, note position of compression dial and readjust if it shifts, but not a very good nor robust design IMO
Posted : 07/12/2010 12:37 pm
09's the same as i had - in that case ditch them and get float RL's ๐Ÿ˜‰
Posted : 07/12/2010 12:41 pm
Might as well. The fact the compression adjuster won't stay in position does render it rather useless. Worse than useless in fact, since it's normally where I [i]don't[/i] want it.
Posted : 07/12/2010 12:49 pm
yeah certainly does, never really used it to be honest, and to be honest i prefer the rl's less faffing, and seem more plush somehow!
Posted : 07/12/2010 1:28 pm
