Stumpjumper FSR BB3...
[Closed] Stumpjumper FSR BB30 crankset play - urgent help please
[#5167840]
On my 2013 stumpy fsr there is a couple of mm play in the SRAM BB30 crankset. We've had the crank off and it already seems unfeasibly tight so I'm wondering if a spacing washer is missing? Has anyone had any experience with this system? I've only had HT2 in the past.
cheers
Rich
Posted : 18/05/2013 11:57 am
 JCL
There is just one 10mm spacer on the driveside. The rest of the slack is taken up with the non-driveside preload adjuster. That's XO and a 12 Stumpy Evo.
Posted : 18/05/2013 3:17 pm
The pf30 bbs can have a very short life , one person I know ride twice washed his bike then put it away for a few weeks . End result bearing sized solid
Posted : 18/05/2013 3:32 pm
If its the bearings just by cheap ones off ebay, prize the bearing seal off, pack full of fresh grease. Then tap out the old ones with a screw driver and press in the new ones using the old bearings. Had the same bb fort a while now and just do this whenever they go. Takes about 15-20 mins to do once done a few times. Got 10 bearings for about 10-15 quid, enough for 5 changes.
Thats on a stumpy evo carbon
Posted : 18/05/2013 5:12 pm
