trueing my wheels
[Closed] trueing my wheels
[#5167847]
can i true my own wheels with a rubber mallett and a flat surface! theyre a bit buckled.
Posted : 18/05/2013 12:22 pm
 Keef
yes,it'll be fine 😉
Posted : 18/05/2013 2:19 pm
No, use a hacksaw and the edge of a fag packet like everyone else.
Posted : 18/05/2013 2:41 pm
What did you do to bend them? It's all about reversing the polarity- if you hit them off a rock on a descent, you have to ride back up that descent at the same speed and hit the same rock from the other side.
Posted : 18/05/2013 2:44 pm
Buy a spoke key and watch some online tutorials. It is pretty straight forward.
Posted : 18/05/2013 2:47 pm
Spoke key plus online tutorials is the way to go.
Also add two vital ingredients, though.
Time and patience.
Don't rush it, you need even spoke tension as well as a true rim. If the spoke tension is all to cock, the wheel will buckle again if you look at it wrong!
Posted : 18/05/2013 2:53 pm
this online book is £9 well spent
[url= http://www.wheelpro.co.uk/wheelbuilding/book.php ]Wheel Pro[/url]
I was truing wheels for 8 years in the bike shop and that book still taught me a few new tips.
I recommend Spokey Pro nipple keys, preferably the ones with the double thickness insert like this: [url= http://www.evanscycles.com/products/rixen-kaul/spokey-pro-ec050244 ]Spokey Pro[/url]
Posted : 18/05/2013 3:07 pm
If they are REALLY buckled then whacking them off the ground to bend them back a little (with the tyre still on) really works quite well. you'll need a spoke key to finish it properly though
Posted : 18/05/2013 4:58 pm
Put them in the fridge overnight
Posted : 18/05/2013 5:01 pm
Fridge! are you mad man?
I think you mean freezer don't you?
Posted : 18/05/2013 5:06 pm
Ah bollocks to all that. I'll take them to my lbs.
Posted : 18/05/2013 9:13 pm
Thought I could just give them a gentle whack with my trusty rubber mallet and they'd be reet. Never mind.
Posted : 18/05/2013 9:14 pm
[b]Northwind[/b]
do you have to ride up backward for this to work or not? 😕
Posted : 18/05/2013 9:42 pm
Swap them with your mate's while he's buying a cheese straw at Peaslake shop
Posted : 18/05/2013 9:52 pm
