Rev dual air to coi...
[Closed] Rev dual air to coil conversion
[#5167837]
So I'm getting a u turn coil from a pike to go into my pike based dual air revelation forks and I wondered if any one else has done this conversion and if so what did they do for the base plate assembly at the bottom of the uppers. Can I just take the one off the end of the air spring and slide it onto the spring rod or do i need to buy the proper spring thing. Have read pretty much all the threads I can find on tinternet but can seem to find any help.
Posted : 18/05/2013 11:55 am
Bump for the night crowd
Posted : 18/05/2013 8:41 pm
Get in touch with Loco, apparently it is straight forwards but you need to buy and fit a negative spring.
Posted : 19/05/2013 11:14 am
