Stumpjumper FSR 6fa...
[Closed] Stumpjumper FSR 6fattie
Has anyone gone from a stumpjumper FSR 29er to a 6fattie (650b +)? How did you find it? Any opinions on the 6 fattie also welcome. Ta.
Posted : 23/09/2016 7:15 pm
Every review I've read online or from riders on here are glowing.
Posted : 23/09/2016 8:16 pm
Dirt did a big review/comparison doing just that, I'm sure some googling would find it
Posted : 23/09/2016 8:20 pm
http://singletrackworld.com/forum/topic/6fattie-comp-carbon-a-mini-review
Hope that helps.
Have only had a brief spin on the 29er and it felt nice and fast rolling, but less fun somehow. I suppose I'd put it like this;
For miles, get the 29er
For smiles, get the 6Fattie
Posted : 23/09/2016 8:38 pm
I have a 29er & love it. A mate from the local bike shop has a 6Fattie. It's amazing. Wish I'd gotten the fattie now but it was a present for my 40th.
Really wish I could retrofit the tyres but the back ends not wide enough.
Posted : 23/09/2016 10:42 pm
Dahedd, I have a stumpy 29er. What makes you want the 6fattie?
PS. Thanks for the comments.
Posted : 24/09/2016 8:07 am
I've recently put some 650b+ wheels in my 29er as an experiment, they fit fine with 2.8 nobby nics. Good fun to ride, a bit more playful and absolutely rails corners with the now even lower BB and added grip.
No issues at either end with clearance, even 3.0" tyres may go in at a squeeze.
Posted : 24/09/2016 8:46 am
I think I've got a fat fetish just now Angeldust. Ended up with a full blown fatbike instead. The 6fattie wasn't available when the Mrs bought me my Stumpjumper at anyway.
I love my 29er, couldn't get used to a mates Cannondale trigger 650b the other day when I tried it out. But my mate Matt has 5 or 6 bikes & his 6fattie is his current favourite.
Interesting pic Mark. Ill maybe give it a whirl at some point. I've got the 2015 version so I dunno if the rear triangles different.
Posted : 24/09/2016 9:08 am
My stumpy is 2013, the 2013 - 15 models are exactly the same.
I had considered extending forks to 160 to lift BB a bit and slackening it out and fitting a 44mm syntace dropper stem to bring bars back down, I think it may be a real weapon then ๐Ÿ™‚
Posted : 24/09/2016 9:37 am
Anything stopping me getting an extra set of standard 29er wheels and swapping between the two on the 6fattie i.e. are 29er wheels in these hub widths readily available?
Posted : 01/10/2016 6:56 pm
Nope, just need boost hubs. superstar do a reasonably priced set of hubs which you can select via the custom wheel build.
Posted : 01/10/2016 7:05 pm
Yep, just get any "boost" hub spacing wheel set, i.e.: 12x148mm rear, 15x110mm front.
Posted : 05/10/2016 2:44 am
I've just built a 2016 29er frame up, it's brilliant. Can anyone confirm if it will take a B plus (2.8) tyre? I specifically got a 2016 model because I didn't want BOOST.
[URL= http://i64.photobucket.com/albums/h167/happybiker18/20160904_114839.jp g" target="_blank">http://i64.photobucket.com/albums/h167/happybiker18/20160904_114839.jp g"/> [/IMG][/URL]
Posted : 05/10/2016 9:48 am
I'd buy this one just for the paint job ๐Ÿ™‚
Posted : 05/10/2016 9:51 am
 LMT
It does look great! ive got a Fuse on its way hopefully get it today or tomorrow!
Posted : 05/10/2016 9:53 am
mark_rich, what Spesh model is that?
You're all making want a new bike ๐Ÿ™
Posted : 05/10/2016 12:12 pm
I'm running my 2012 stumpy 29er with B+ tyres, and it is fun. I've swapped back and forth between my normal wheels and the B+, both have pros and cons, but depending on the riding you do I don't think you'd regret it...
Posted : 05/10/2016 1:49 pm
Thanks for the info, the 2016 has a shorter back end so I'm not sure it will take a B plus tyre.
Posted : 07/10/2016 10:01 am
I saw a post of Facebook that they should have called it the Plumpjumper.
Posted : 07/10/2016 10:34 am
Plumpjumper.
Excellent ๐Ÿ˜† That's what I'm calling mine from now on.
Posted : 07/10/2016 11:32 am
bomberman - Member
Sorry for slow reply but it's a 2013 29er expert evo carbon
Posted : 13/10/2016 10:06 pm
