Stump jumper FSR re...
[Closed] Stump jumper FSR reverb dropper question
Looking to see if on a 2012-2014 Stumpjumper FSR Large frame, if you can lower a 420mm reverb all the way down so the collar sits on the seatpost clamp. I'm looking to upgrade frame/bike but need the above info.
Thanks people
Posted : 07/12/2015 7:40 pm
I have a large Stumpjumper and a 420mm Reverb, the answer is yes.
However, you'll need to route the hose externally or have the port drilled out slightly, as the Stumpy frame can only accept a 4mm cable, not a 5mm hose.
Posted : 07/12/2015 7:45 pm
Thanks for that, should be ok as I have an old externally routed reverb that I could use.
Posted : 07/12/2015 7:47 pm
Just another thought, looking at Evo model, would it still be the same.
Posted : 07/12/2015 8:11 pm
The evo front triangle is the same as the non evo one as far as I know, the magic happens around the shock ๐Ÿ˜€
What PJM was getting at is that you can run a dropper remote through part of the top tube, it exits by the shock. Unless it's carbon you can't use a stealth one without drilling holes in the frame
Posted : 07/12/2015 8:33 pm
Both the alu and carbon Stumpy frames have a dropper remote port that is ever so slightly too small for a Reverb hose (it enters just behind the head tube and exits around the rear shock), but fits the slightly smaller Specialized Command Post cable perfectly.
Posted : 07/12/2015 8:42 pm
Thanks guys,
Posted : 07/12/2015 8:54 pm
