Stuck seatpost in a...
[Closed] Stuck seatpost in a Ti frame
 BigR
Completely my fault but my seatpost is completely stuck. I have tried plusgas, GT85, ammonia, freezing spray and hacksawing down the length with no joy. Is there anywhere in Edinburgh/Glasgow or further away that someone can recommend who may be able to ream it out? Thanks
Posted : 10/04/2015 8:14 pm
ben @ kinetics has all manner of conferluting machinerwhattery that might help.
http://www.kinetics-online.co.uk/
Posted : 10/04/2015 8:26 pm
 BigR
Thanks, I'll give them a call.
Posted : 10/04/2015 9:43 pm
http://www.theseatpostman.com/
Posted : 10/04/2015 9:46 pm
 BigR
Rorschach, sounds promising, have you used him?
Posted : 10/04/2015 11:56 pm
Plug it pour patio cleaner in the frame, eats aluminium cleans titanium
Posted : 11/04/2015 12:18 am
It doesn't help you now but it's likely to be galvanic corrosion and titanium can also be prone to galling (so is aluminium). In galling a sliding action picks up the surface into tiny lumps, done enough it can weld parts together
If the metals are dissimilar without seatpost movement, I'd suggest galvanic corrosion
If you move your seat post frequently for transport, or if it regularly slips then you might begin to see galling
Posted : 11/04/2015 9:28 am
I had this recently on a bike I was working on. wd40, leverage, impact hammers etc wouldn't budge it. Eventually did the cutting into 4 slices lengthways, at first this seemed to achieve nothing but I found that a small screwdriver gently tapped into the gap between post and frame followed by a bigger screwdriver, repeat, repeat, repeat eventually got it to move once the screwdriver reached the seized area. Took 8 hours to do all this and drove me slightly insane.
Posted : 11/04/2015 10:41 am
The effect that seriously corroded aluminium can have, as the aluminium oxide expands:
http://www.pardo.net/bike/pic/fail-001/FAIL-102.html
Posted : 11/04/2015 11:00 am
Yup, pop it along and I'll shift it - I have a series of techniques that haven't failed yet ๐Ÿ˜€
(though may have to destroy the seatpost itself)
Posted : 11/04/2015 11:27 am
