Struggling to find ...
[Closed] Struggling to find correct front mech
Guys,
I am calling on your collective wisdom because I am really struggling to find a truly compatible front mech for my Specialized enduro 2004. I had a shimano LX M570 and with a 34.9mm clamp. The original mech has worn out and the pivots have that much play it doesn't shift correctly now and the bike is not rideable.
I want to keep up riding through the winter and this is hindering me!
Can anyone recommend a suitable alternative or do you have a M570 mech. I *think* its a top swing bottom pull.
Thanks
Mr. Desperate!
Posted : 31/10/2012 10:43 pm
Is it fairly compact, ie, the cage and mount are on the same plain?
Or is the mount much higher than the cage?
High up = Bottom swing, low down = top swing. Most are dual pull nowadays.
My 05 spec FSR worked with either swing, and was bottom pull. I'd say you'll be fine with any 34.9 mech!
Posted : 31/10/2012 11:34 pm
