Struggling to find ...
[Closed] Struggling to find a 130mm 650b full sus
I might be missing something but the Intense Spider is way over my budget of 2k ish. Is there a cheaper version?
Posted : 15/01/2015 12:29 am
typically I havent read all of that, but would thoroughly recommend the mega tr275....I've been really impressed by mine, rides long days ok, jumps well and is good on the tight twisty steep stuff.
currently cheapish on crc too.
Posted : 15/01/2015 9:44 am
I like the Nukeproof but think 150mm up front is overkill for xc. I'll have a look at the rest of the range tho.
Posted : 15/01/2015 10:08 am
Why don't you get on with steep seat angles?
Because I end up wanting the saddle further back. I understand the logic of the designer - shifting weight forward to deal with a lighter front end to aid climbing. But I like my saddle relative to the cranks, not the bars, and 75+deg is just too TT for me. I run a Trek Remedy and, like I said, with alayback it's just about fine but with the Reverb stealth the saddle is just too far forward. Obviously on the way down stuff it's irrelevant but on more XC sections is just too far forward. I have quite long femurs though... so this is just me.
Posted : 15/01/2015 10:31 am
Theres an interesting discussion of reach/toptube/seat angle here
Posted : 15/01/2015 11:47 am
I've been reading up on the Norco Sight and like what I'm reading. Being a bit out of touch with current tech how would the Sight compare to my old 100/115mm FSR for XC rides? I know it will handle rough trails better and be much more stable on decents but thinking about climbing and flatter rides too.
Posted : 15/01/2015 12:12 pm
Most roadbikes are even steeper than that.....being way behind the cranks isn't very efficient.
Anyway you can get these http://www.sjscycles.co.uk/vk-saddle-adjuster-prod1249/
and even saddles with extra long rails if you can't find a a dropper post with enough layback eg http://www.sellesanmarco.it/en/aspide-carbon-fx-open
Posted : 15/01/2015 3:15 pm
Are you riding flats or clips? With flats you can put your feet further forwards whilst with clips you can move the cleats backwards, both of which will give a slacker effective seat angle.
The other thing that the Transition document about reach vs ETT doesn't mention is that the higher the stack height, the longer the ETT for the same reach and seat tube angle.
Posted : 15/01/2015 3:41 pm
There's a good discussion about that here:
http://forums.mtbr.com/knolly/long-reach-wheelbase-discussion-928997.html
including some input from Noel from Knolly.
Posted : 15/01/2015 3:44 pm
I find a long reach and long wheel base actually helps me in the tight stuff, it gives me loads more confidence loading up the front wheel without feeling like I'm going to wash the front end out.
You go light on the rear and pivot around the front wheel letting the rear wheel slide sometimes, it's a different style to how a lot of riders used to ride, with either weight equally distributed or with a heavy bias to the rear and light on the front.
Posted : 15/01/2015 3:56 pm
So after reading up on these bikes a lot i think my list has been refined to:
Whyte T130 / T130 works if possible
Norco Sight 7.4
Commencal Meta Trail Essential
Really appreciate all the input it's helped me lots.
Posted : 15/01/2015 9:29 pm
Rocky Mountain thunderbolt?
http://www.bikemag.com/videos/rocky-mountain-thunderbolt-2015-bible-bike-tests-roundtable-reels/
Posted : 15/01/2015 10:01 pm
In terms of value for money / spec, the T130 is well in the lead, from that list. The works version is stunning.
Posted : 15/01/2015 10:02 pm
I took a punt on a Whyte m109c without really trying before buying ,but I did the reviews , im so glad I did , There is a reason Whyte bikes get a glowing review T130 for me mate
Posted : 15/01/2015 10:09 pm
Most roadbikes are even steeper than that [75.5deg].....being way behind the cranks isn't very efficient.
No they aren't. Most are between 72 and 74.
Posted : 15/01/2015 10:51 pm
That Rocky Mountain is lovely but way out my price range.
Posted : 15/01/2015 10:52 pm
Think there are quite a few cheaper versions?
Posted : 15/01/2015 11:24 pm
So a trip to a couple of bike shops are planned. I did a bit of research on reach and head angles and the Transition Scout doesnt seem much slacker than other mid travel bikes so thats back on my list. Quite like the idea of less rear travel. Something like a 130rear /140front might be a good setup for me.
Posted : 16/01/2015 1:48 pm
Ok, i've had another think about what most of you have said about not worrying about the travel too much. Looking at som of the suggested bikes have opened up a few more doors. Thinking about how my riding has changed over the last couple of years; i tend to be the one during ride to hit the stairs faster and look for fun trails rather than the quickest way to the top, i think a more 'fun' bike would be better suited. So if i was looking at an efficient 140/140 trail bike what should i look at? I read about the Norco Sight which is still on my list but are there any others that are can still be peddled efficiently?
Posted : 16/01/2015 10:07 pm
If you want "fun" then the Pyga should definitely be on your list.
Posted : 16/01/2015 10:15 pm
Transition bandit 650b. Nice new frame for sale over in the classifieds. 😀
Easily complete a well spec'd build for under £2k.
Posted : 16/01/2015 10:16 pm
My Whyte T130 Works is a great bike sadly not riding it due to damaged shoulder/collar bone but the moth I did get out on it it was simply superb.
Test ride is your friend in these situations.
Posted : 16/01/2015 10:48 pm
The seat tube angle isn't static though on a full susser is it?
As soon as you sag the bike, it was my understanding that the effective seat tube angle becomes a fair bit slacker. The Scout will end up at 73.5 or 74.5 when sagged depending on the size of the bike, won't it?
So about the same angle as a racey road bike.
Posted : 16/01/2015 11:43 pm
That's the scout then, or that bandit frame. Mine is the 650b one and it pedals uphill great! Good enough for top ten on strava on a quantocks climb anyway
Posted : 16/01/2015 11:50 pm
Is the transition bandit a current model or 2014 only?
Posted : 16/01/2015 11:56 pm
bandit 650b was 2014 only. It was 26 before that and I guess the scout now replaces it in the line up with the patrol replacing the covert as well.
Posted : 17/01/2015 12:12 am
I'm still liking the look of the scout but worried it will be unsuitable for fast xc rides.
Posted : 17/01/2015 12:52 am
Go on a demo ride and find out.
Not sure if its still the case but a couple years back Transition had a demo fleet that they could send out to your LBS.
Posted : 17/01/2015 3:32 am
Well it's not a race bike but I think it would be fine. The bandit I have has beaten every strava pr I have up and downhill, it keeps pace with everyone I ride with, 29ers and hard tails included, it's done day rides on exmoor and quantocks, not sure how much more xc you need? The scout is supposed to be the same fun bike downhill with better pedalling suspension.
Posted : 17/01/2015 11:55 am
To expand, I demoed amongst others a 5 and a transition covert before getting the bandit. Both the 5 and the covert felt like you were "carrying" a lot of unnecessary bike on the fiat/ uphill bits (although the covert was a smooth monster going down) the bandit never feels like it's too much bike on the trails.
I think with the advances in suspension and geometry since your old bike was new, you might be surprised by how well these bikes pedal. I think any of your options is likely to a good one! Everything has some kind of compromise it depends on where you make it. If you want something that excels at fast xc rides then you are going to compromise fun descending and be looking at somthing like a spesh epic. If you're not racing though, I think you will find that a modern mid travel trail bike is plenty quick enough
Posted : 17/01/2015 12:30 pm
Thanks ceepers. I've started making a list of the pros and cons of each bike on my list and any compromises.
Posted : 17/01/2015 3:11 pm
Absolutely this. Or your local Transition dealer may have their own demo fleet. If they don't, surely worth travelling to somewhere else with great riding and a range of bikes to try. Just sayin'.
Posted : 17/01/2015 4:13 pm
While looking at frames I'm noticing more have a direct mount front dérailleur. If in the future I have a 1x10/11 setup will this cause a problem or just look a bit messy?
Posted : 17/01/2015 11:01 pm
It won't cause problems. Can look a bit messy but you might want a chain guide - if not then blanking plates are available.
Posted : 17/01/2015 11:03 pm
Transition have some 2015 demo bikes available already, I've had their smuggler out myself. I'd get in touch with your local dealer for a demo.
Posted : 17/01/2015 11:17 pm
What did you make of it? It's the one I'm most looking forward to getting in, to be honest.
Posted : 17/01/2015 11:40 pm
Anyone know much about the Giant Trance 1 with dual position revs? Looks amazing value and quite like the frame.
Posted : 18/01/2015 2:01 pm
Right I'd made my mind up to go with the Whyte T130s and it turns out I can get hold of the T130 Works in a sale for not much more over my budget. Now I know it's a better bike but is it worth stretching my budget a little to get it?
I keep trying to justify it by telling myself I haven't bought myself a new bike for years and have recently really got back into it.
Posted : 19/01/2015 8:08 pm
I don't think you'll end up disappointed if you go with a better-specced bike than you envisaged. I've never heard of anyone saying "I wish I'd bought a lesser bike". If you can afford it, and especially if it's a good deal, I don't think you'll wish you'd bought the cheaper one.
Have you test-ridden that bike though? I wouldn't buy a bike based on what some people on the internet said.
Posted : 19/01/2015 8:22 pm
Sure you will love it!
Worth considering that the works is single ring specific, if that's ok for you then go for the works I'd say
Posted : 19/01/2015 8:37 pm
It's an awesome bike and WELL worth the upgrade over the S version. Wheelset, fork, brakes, 1x11 drivetrain, saddle are all markedly better.
Careful with sizing without test riding. What is your height and inside leg?
Posted : 19/01/2015 8:57 pm
I'm 5ft5 and ride a small Specialized currently.
I need to pay a small deposit to get one into the store before full payment. Theres no demos anywhere near me to test ride.
I should be fine with 1x11. I'm ridding a 2x9 with 26/38 x 11-34 and rarely use the granny ring.
Posted : 19/01/2015 9:08 pm
I expect you'll fit well on the small. Medium might be that bit big but it'll be borderline, so may be worth a capark pedal on both.
Posted : 19/01/2015 9:18 pm
These get great reviews
http://www.saracen.co.uk/bikes/all-mountain/kili-flyer-team
Posted : 19/01/2015 10:01 pm
The Sarecens nice too. I did look at their site the other day but keep going back to the whyte.
Posted : 19/01/2015 10:39 pm
Page 2 / 3
