I snapped another chain yesterday and bashed my knee on the stem. To be fair it wasn't new, but it broke quite spectacularly. Do chains get stronger the more you spend? I'm looking at one of these spangly ones
from KMC,
http://www.highonbikes.com/kmc-x9-l-gold-9-speed-chain.html
Any good?
IME/O, they don't.
How did yours break?
how many have you broken?
if its more than one, and they weren't old. i'd suggest setup/technique.
It is my second in a couple of months, broken when cranking up a short steep hill standing up. Orange alpine 160, 1x9 and e13 LG1+ chainguide.
I'd say its more likely to be setup or technique rather than the chain itself.
Were you changing gear at the time?
Did you stamp on the pedal?
Was there a stiff link in the chain ie where it was joined?
Is the cassette or chainset worn?
Are you using the correct joining pins if its a Shimano chain etc
Best I had was PC991 cross step
ran 1x9 and didn't snap it
No, they get lighter.
Pretty sure the set up is fine, I wasn't changing gear as it was too late to do so and would likely break the chain! Not stamping, but using some muscle.Almost new renthal sr4 and sram redwin DH cassette and it broke into two halves, not on a power link.
IME all my snapped chains were down to technique and forceing the gears to change too quickly, never snapped a chain with rapid rise mechs, lots of foreward planning and shifting before the gears needed not when it's needed and I've not snapped one in years.
It's not nececeraly shifting that snaps the chain, it just forces it to work at a sharp angle between the mech and cassett that forces the outer plate works off the rivet, so the next time you apply some power it pulls the link appart. So the dodgy shift could have occoured minutes/hours/days ago.
Thanks tinas, all the excuse I need to push instead of pedal! :-)So the general consensus is they are all the same?1
wot TINAS said, I think.
I try not to shift under pressure, I don't snap chains.
Check out YBN Superstrong.
They have compensated for my bad technique, and lasted longer than others I have tried.
My chain snapping reduced dramatically ( completely ? )when I swapped, from FSA chainsets to Shimano.
The only test info I saw said the chains with shorter pins tended to have the highest strength. And that strength was a UTS of such a high number that there's almost no way you'd break a chain with pure pedal force, it'd need to have been fitted wrongly or be damaged somehow first. Or, you're Chris Hoy.
Well I have just ordered a gold KMC chain and shall endeavour to be less clumsy in future.
I have the same gold KMC chain - I like it.
