Last night the driveside crank's pedal thread stripped out on my friend's bike in the middle of a ride. S* happens, but they're nice cranks and we'd like to rescue the crank if it's possible.
Helicoiling is one option that springs to mind but is this a viable long term solution? it needs to be as straight as possible too which I imagine would only make the job more challenging than say 'coiling threads on a stem.
If it's of any help these are made of 7075. Some places say they'll only helicoil softer 6-series cranks. I'm not sure why. Does anyone know of a good bike shop or competent mechanic that can repair it?
Hi,
I would personally organize steel sleeve with proper pedal thread and set it into the crank arm by pressing and/or liquid metal gluing.
Cheers!
I.
Helicoil would be fine. That said those cranks must be getting a bit old now, might be time to think about retiring them or moving them to a pub bike. Seen a few fail
That "nice crank" looks like it has been used as a hammer ? Is it worth an expensive repair
They used to live on a trials bike, now on my friend's 26" SSer.
Rescuing them would be the cheaper option than say getting a Zee crankset which is plan B if repairing the thread goes pear-shaped.
Who can get it done well?
I've had some luck in the past threading in a tap from the other side - Can't tell from that pic how much meat is left.
May be worth a try first?
Are middleburn small enough to send it back to for a repair.
Helicoil would sort that.
You could machine it out n plug it with an insert but I'd try a Helicoil first
I have some nice shiny proper nearly new ones FS
Fully recommend Highpath, done a lot of excellent work for me in the past.
