Stripped crank thre...
[Closed] Stripped crank thread - warranty case or my fault?
About a quarter mile from home today the driveside pedal on my Roadrat started to feel 'weird' - coasted home and found that the pedal had come lose, and as it is a steel spindle in an aluminium crank, it was the crank thread that was stripped, not the £20 pedal.
The bike is new - probably done 300-400 miles over the last 2 months so part of me thinks this should be a warranty case, but the counter argument is that threads don't strip themselves so I must have done something wrong!
I'm pretty sure I haven't cocked up - given the steel/aluminium combo and the fact the pedals have a 8mm hex key rather than spanner flats I've been hyper-aware to make sure a) the thread is properly greased and b) I don't over tighten it and strip the threads.
Given a new crankset is about £100 quid I'm not sure it is worth the time it would take to go through a warranty claim, particular as it is my main mode of transport to and from work!
On a related note, I do have a raceface 1x crankset in the garage in preparation for a future build - any reason why I couldn't use that with a 38T or 40T narrow-wide chain ring? The bike has an Alfine hub gear - should I anticipate any issues with getting the chain line sorted?
Posted : 11/08/2016 4:37 pm
You haven't really suggested how or why it could be a warranty?
The differing materials are not relevant.
Sounds like you fitted them without doing so tight enough. FYI it's pretty hard work to over tighten a pedal into a crank to the point where you strip it. Not sure what the correct torque but it's pretty firm!
Only way it could be a warranty is if the pedal was pre fitted when purchased.
Posted : 11/08/2016 4:43 pm
This.
If you've fitted the pedals you've either cross threaded them or not done them tightly enough. Neither of those is a warranty issue. They won't have spontaneously stripped from properly tightened.
Posted : 11/08/2016 5:10 pm
you can get the cranks fixed I think the things are called helicoils
Posted : 11/08/2016 5:13 pm
And while you're at it you might want to file down the end of the pedal where you dropped it and bent the thread.
Posted : 11/08/2016 5:21 pm
