Strava map flipper ...
[Closed] Strava map flipper not working?
Anyone having trouble getting the OS map flipper (from veloviewer) to work in strava? Not working for me in any browser at the minute - something up with my settings or has it been withdrawn?
Posted : 26/11/2014 1:17 pm
I found the same, and couldn't see any reports on t'interweb about it.
However, I have found a workaround - if you activate the flipper, and then on the Strava map select satellite maps, it will draw the OS maps over the satellite imagery.
No idea why/when the change was made...
Posted : 26/11/2014 1:25 pm
Nice one gareth, that works for me. Civilisation is restored - strava routes on OS maps ๐Ÿ™‚
Posted : 26/11/2014 1:48 pm
Anyone found a way for this to work with the global heat map?
Posted : 26/11/2014 1:55 pm
I don't know nickjb, but it definitely used to work with the heatmap as I used it to plan some routes earlier in the year.
It must be a simple script, so a STW IT person would prob understand what the problem is.
Posted : 26/11/2014 2:05 pm
Has the Strava map flipper packed up again for anyone else?
Even the 'satellite' map workaround has stopped working for me :o(
Posted : 12/01/2015 1:52 pm
I noticed it had stopped working about the same time. If you delete your existing mapflipper bookmarks, then re-make them from the VeloViewer page here:
http://veloviewer.com/mapFlipper
Then they should work again.
Hope this helps.
Posted : 01/02/2015 4:53 pm
