Strava adiction
[Closed] Strava adiction
that's the best way atlaz!
now that the popularity of it is increasing it's getting a whole lot harder to keep up the top of the hit parade round here.
However I quite like knowing where I'm losing time to people (on climbs it's obvious, on downs not so much). It was always interesting to see where I drop away from people fastest when back in the UK as it helped me realise where I could probably easily get faster without as much risk. Here it'd be nice to have the same benchmark.
Posted : 02/04/2012 9:55 am
I've only recently discovered it and can't wait to get over to some familiar trails and getting the position back up the rankings!
The road climbs are humbling though, i think i'm 800th or something up Box Hill!
Privacy is definitely lacking on this site though. It says your name will be "anonymized" on the rankings, but then it shows your actual real name.
Posted : 02/04/2012 11:08 am
Are you sure that is just because you are viewing it logged in? Try loggin out, or using a different browser and checking. You should then see the privacy settings applied, as that is how others will see you.
Posted : 02/04/2012 11:14 am
[i]I think I may have to re-register as a girl....that way I will only be getting beaten by a slightly less embarrassing margin. [/i]
there's a whole online persona to be built there.
stw
twitter
strava
As long as you always ride solo no one will ever know 😉
of course, in my case, I'd still be rubbish as a girl rider.
I do like Strava, although I can see it turning every ride into a race.
Posted : 02/04/2012 11:16 am
Check out some of the Pros rides/races....79mls....28mph avg
Posted : 02/04/2012 11:34 am
I've only just discovered this, used it 3 times or so just to see my distance, elevation and times but on a ride this morning I got 2 achievements on the same route, wasn't even aware of this function, nothing special but it's got me thinking now everytime I do that route I'm going to try harder on those sections!
With hiding your address, you can crop the start and end point when you've uploaded - I've only been messing around with it this morning but I assume you can upload as a private route, edit, then make public? I did look at adding my address but the miniumum distance is to block everything from 500ft from that address which seems a lot to me, thought it would be better if you can add your own distance?
Posted : 02/04/2012 12:11 pm
you can change the distance to 1km etc.
also, pick two or three local postcodes and block all of them so you end up with a 'fuzzy'; edge to the exlusion zone - makes it more difficult to find a 'centre'.
Posted : 02/04/2012 12:24 pm
I had a guy email me this other week
"My nemesis on Strava!!! .. I have taken your KOM up stoke park and bell hill.. I challenge you"
I actually didn't realise I had a KOM as this was the day i wanted to find out how far my commute was (using my dawes steel tourer)
Posted : 02/04/2012 12:38 pm
Just joined the STW group for this and have been checking out my local "segments". One of them is a climb towards the end of my local short road loop that has invariably has me gurning and burning by the time I reach the top of it.
I can only conclude that the KOM for that segment was hanging off the back of a milk float when he set that pace. Going up it that fast doesn't seem humanly possible. 😡
Posted : 02/04/2012 12:59 pm
I've just deleted a few rides from strava that I'd imported from Mapmyride. The GPX had my speed as the average speed for the ride and as a result I had some improbable KOM's...
Posted : 02/04/2012 1:04 pm
re private area: since I ride in all directions, I didn't use home as the centre, I used a nearby bike shop with a 1 mile circumference which my home and neighbourhood falls under.
Posted : 02/04/2012 1:43 pm
You can add a number of postcodes to create an exclusion zone. Adding one will make it fairly easy to triangulate the centre if you arrive home in different directions. Overly paranoid perhaps, but given the number of high-value bike thefts in Bristol recently I'm taking no chances.
Posted : 02/04/2012 1:52 pm
Having just returned from Afan i thought I'd see what times were set on thesegments were listed and was surprised to see that the White's climb has had its times & KOM/QOM removed with a note saying it's been reported as 'hazardous'!
[url= http://app.strava.com/segments/644751 ]http://app.strava.com/segments/644751[/url]
Posted : 02/04/2012 3:07 pm
Just been for a quick road ride, taking in about 8 segments. got one KOM and am 15-30 secs off the pace everywhere else! I've got a lot of work to do, especially as I was going flat out (I thought!).
This could easily be the new Call of duty for me!
As an aside, stopping at traffic lights, presumably adds to my time? I can see a few nocturnal TT's coming up!
Posted : 02/04/2012 3:11 pm
hit the 'report abuse' button and get it overturned - explain it's a designated mtb trail and a climb!
maybe someone lost their KOM and spat their dummy?
Clicking the Report Abuse link just throws me back to the homepage :-/
Posted : 02/04/2012 3:18 pm
Only a second off KoM for the Beast of Hope Cross short segment.....it's great to be able to see where I'm losing/gaining time on people (in this case it's the looser bits). I don't think it's too bad considering I'm on my hardtail. Cained the Screaming Mile the other day too, which was a nice surprise 🙂
Posted : 02/04/2012 3:20 pm
Ignore me - it worked 2nd attempt.
Posted : 02/04/2012 3:31 pm
Haha, I got fifth and I stopped halfway down for a rest (it was the end of a long day). Must get back there quick (possibly with DH bike) before Strava gets more popular!
Wow, just re-read your post and noticed you were on a HT. Good going!
Posted : 02/04/2012 3:33 pm
What handlebar mounts are you lot using or do you just leave it in pack/shorts?
Posted : 02/04/2012 4:16 pm
i'm stuck in the 18th century with a steam powered phone, anyone have any thoughts on these things?
[url= http://www.maplin.co.uk/bluetoothandreg-gps-travel-tracker-351568 ]cheap gps box?[/url]
Posted : 02/04/2012 4:25 pm
Chaz Davies the world superbike rider has a few KOM's around my area...He's fast!!!
Posted : 02/04/2012 4:50 pm
I do think there should be an element of caution in creating segments for descents in trail centres.
That has the potential to make it dangerous for everybody not just the person chasing the KOM.
I only really push climbing segments hard.
Posted : 02/04/2012 4:56 pm
I don't want to sound like a bed-wetting lefty but I agree with this! Besides, anyone can hoon it downhill. Climbs are the true tests for manly men. 😆
Posted : 02/04/2012 5:22 pm
right, I'm in - god help any poor bastard that messes with me
(awaits REALLY windy day before creating and ruling a couple of likely looking segments)
Posted : 02/04/2012 6:46 pm
 DT78
So how long before the first strava related incident is reported then.... Someone trying to get kom and running over a rambler on a blind bend...
Posted : 02/04/2012 8:25 pm
Strava is making me kill myself on my commute! Still got a KOM and a 3rd overall on the way home this evening 🙂
http://app.strava.com/segments/1159230
http://app.strava.com/segments/980280
Posted : 02/04/2012 8:29 pm
Yeah ain't they. I thought hoping for top 50% on the ZigZags wasn't ambitious, turned out I am 700/1000. Only 30s to drop for top 50%, it's doable! Again again again!
Posted : 02/04/2012 9:16 pm
I've just added a couple of downhill segments on the Quantocks (The Chimney and Somerton Combe) does that make me a bad person 😳
Posted : 02/04/2012 9:27 pm
 dobo
Strava is way hard to compete on road with a mtb or knobly CX but I've just spotted a few good off road climbs which are all ready segments which i'm positive will be mine soon 🙂 muhahaha
Posted : 02/04/2012 9:33 pm
my club is having a lot of fun with this in the FoD, sad to hear segments are being removed, no doubt land owners/authorities will catch on
Posted : 02/04/2012 9:44 pm
Just signed up.
Can see how it can get competitive. Uploaded a couple of my London Commutes.
Got the Upper Street, Islington KOM! I'll put a bit of extra effort in now!
Posted : 02/04/2012 9:48 pm
Each to their own but it has become a bit of a problem in Aus where people are thrashing down trails yelling out "Strava Run!!" and expecting everyone to get out of their way.
I know there are a couple of segments on the Taff trail in Cardiff which is a busy multiuse path used by walkers, kids, horses and dogs - having people pushing hard there is pretty dodgy too IMO.
Can i do a batch download of my gpx files from endomondo and upladd into strava?
Posted : 02/04/2012 9:54 pm
The Chimney and Somerton are pretty unlikely to be classed as multi use.
Posted : 02/04/2012 9:56 pm
Yes, download the gpx files and them email them from your Strava registered email address and they will all appear.
I have the app but suspect it will chew the battery so I'm using Oruxmaps on my android phone and just emailing the gpx file once done.
Posted : 02/04/2012 10:11 pm
@gee
I need to go and get my Belgium bun KOM back.... The last time was on a rigid SS so may have to go better equipped next time...
yer i need to switch to a 26er... giant (size not make) 29er is not helping though the twisty bits... well that is my excuse and I'm sticking to it.. 😉
bum my concrete hill KOM has gone as well.. 🙂
http://app.strava.com/segments/937978 - 10 secs quicker is good going i reckon...
sure this will go soon as well:
http://app.strava.com/segments/1026555
Posted : 02/04/2012 10:26 pm
I pushed the trail centre descents hard before Strava and as hard after. If I'm feeling "On it" I will go hard leaving gaps etc, sure had some close calls and some crashes but otherwise it's a bit boreing... race to top of hill and coast down ffs is this a roadie game?
Posted : 02/04/2012 11:12 pm
Lewis King is a former pro DH rider, now racing XC - silver medal in the vets national champs last year and a victory in the first NPS this year. Good rider.
Plenty of Gee's times are on 29ers, that excuse doesn't really work anymore!
Posted : 02/04/2012 11:54 pm
Been using it for a year or so now. Its certainly a fantastic training tool.
Heres my profile if anyone wants to see what riding in Colorado is like:
[url= http://app.strava.com/pros/111848 ]http://app.strava.com/pros/111848[/url]
So far this year:
> 1,870 miles
> 136 hrs 13 mins
> 60 rides
That's one ride every 3 days, not too bad!
Posted : 03/04/2012 12:10 am
 mrmo
In theory a trail centre shouldn't have any random dog walkers in the middle of the track after a blind bend. Move to a bridleway with a ton of horse meat round that blind bend and your talking a very different scenario!
But from experience the number of times you go round a trail centre corner to find someone mending a puncture in the middle of the track is unbelievable!
Like most things use your head and think before you decide to race a section.
Posted : 03/04/2012 7:00 am
Having your packed lunch on the boardwalks at Afan is a popular thing to do too.
Posted : 03/04/2012 7:45 am
Just downloaded and glad someone's added some downhill routes on the quantocks cause I know I'll never be that quick up a hill
Posted : 03/04/2012 8:05 am
 will
DT78 - Member
Already happened...
http://www.berkeleyside.com/2010/07/05/did-bicycle-web-site-contribute-to-cyclists-death/
Posted : 03/04/2012 9:49 am
 DT78
That's a bit sobering
Posted : 03/04/2012 1:37 pm
Page 3 / 7
