Storing bikes in th...
[Closed] Storing bikes in the house. Clever ideas required.
So I really don't want to put the new bike in my shed. It's a good shed, has security bolts and a ground anchor but it just doesn't feel right putting it out there. Especially with the amount of shed break ins lately.
Im just looking for people's advice regarding this.
I don't have much space and wondered what people's outside the box ideas are for keeping bikes inside the house.
I'm thinking wheels off and frame hung to the wall in the porch.
How are people storing thiers indoors if they don't have much space?
Posted : 16/02/2016 10:19 am
Mine currently live on a [url= https://www.feedbacksports.com/shop/velo-cache-black/ ]Feedback Velocache[/url], front wheels off to reduce length a bit, tools and spares boxes underneath, helmets and bags hung on the wall behind, extra sticky-backed hooks attached to the stand to hold shoes.
Posted : 16/02/2016 10:27 am
I've got a couple stored wheels off in the attic & road bike in the hall.
If someone breaks into the garage,all they'll find is the winter hard tail covered in mud & minus wheels,pedals & seat post..
Posted : 16/02/2016 10:28 am
Assuming your BB has a 20mm hole: http://andystand.co.uk/
I have three of them holding my bikes upright in the spare room. Easy to move the bikes around and get them out the stands. Great bit of kit.
Posted : 16/02/2016 10:29 am
Got a stand that takes 4 bikes on a pole, header version of the topeak one
Posted : 16/02/2016 10:31 am
hang them from the ceiling if you have enough height???
Other than that he general rule is to put them in a room with enough space for them
Under the bed, Behind the sofa, wherever you like
Posted : 16/02/2016 10:33 am
I use a couple of bike storage hooks fastened to the wall in a spare room. Gets them off the floor, and far less intrusion into the room.
Think they cost £20 each.
Posted : 16/02/2016 10:34 am
Topeak TwoUp here; only two bikes on it, can take up to four.
Turn your living room into a theme pub and make the bike part of the decor.
Posted : 16/02/2016 10:36 am
When we finally got boiler upgraded to combi the cupboard that had old water tank in now holds two bikes upended with front wheels in hook 🙂
Posted : 16/02/2016 10:37 am
Our combi boiler is in the bathroom 🙁
The only real space I have is in a porch. I thought maybe stood upright with the front wheel hooked onto the wall.
Or I just admit that it's the shed and make sure that the insurance covers it.
Posted : 16/02/2016 10:44 am
I have a four bike saris stand in the living room, it is a temporary measure that MrsMover hates. It takes up loads of room, can't wait until we move house and I get a man cave like I used to have.
Posted : 16/02/2016 10:50 am
Well if you do use the shed take the wheels,seat post & pedals off.At least that way they're walking off with it ,not riding it away.
Posted : 16/02/2016 10:51 am
I've got one on a hook from the ceiling, wheels off. It will hang on the hook with the wheels on but sticks out a bit. That'd fit in our porch and it isn't huge. The commuters and main mtbs are in the laundry wheels on hooked onto some shelf brackets. Does take up a bit of space. Last couple of rental properties they were under the stairs
Rent/buy a house with an extra bedroom just for bikes?
Yes, the estate agents do talk to you as though you're mental.
Posted : 16/02/2016 10:52 am
[url= http://cycloc.com/ ]Cycloc[/url] Do wall storage which look a bit less 'garage' than a normal wall hook.
I will probably go for something along the lines of a Velo Sock for when I need to keep MTB in the house.
[img] ?v=1425742236[/img]
Posted : 16/02/2016 10:53 am
Go to any motorcycle shop and they'll give you those "andystands" free of charge!
The come in the axles in the crates new bikes are shipped in - 4 per bike.
They get scrapped.
Posted : 16/02/2016 10:54 am
We have an under the stairs but the new long, slack and low geometry (they didn't think about that did they!) makes even the frame alone too long.
If I can't make the porch work I might have to look into alternative outside storage (Asgard).
Posted : 16/02/2016 10:56 am
[edit, crossed posts so it doesn't make sense anymore] I used to take the wheels off my nice bike and keep it in the cupboard under the stairs. Takes up surprisingly little space if you put some other stuff in there with it (veg rack, clothes rail for coats, etc) so that it didn't end up taking up space that should have been for other stuff.
Just became part of the Friday night ritual to get it out in the kitchen, put the wheels on, do the minor fettling etc. Kept a SS in the shed for weekday riding.
Posted : 16/02/2016 10:58 am
Hooks and walls.
Hangers.
Lots of options. I use hooks and a proper bike hanger. Budget of £30 or under. You could spend £100's on designer hangers that look awesome displayed in the home.
I just wanted to protect my bikes against my dyspraxia family. Don't use on pink sheets to stop scratches. Use radiator pipe foam cut to size.
Posted : 16/02/2016 10:59 am
I'm with Bustaspoke, they go in the loft though we have plenty of room & the garage is well protected, when not in use for a few days they go up in a insulated boarded out loft.
The cupboard is waist height 🙁
I thought I had it a minute ago with a hook in the porch. Then I realised the only full height wall is a glass window.
Do sucker bike strength hooks exist?
Posted : 16/02/2016 11:11 am
There are suckers that carry 800kg glazed units so yes bike strength ones are out there 😆
Posted : 16/02/2016 11:16 am
not sure i would trust suckers for a long period as they will tend to creep. Can you hang something from higher up?
Posted : 16/02/2016 11:21 am
"I thought I had it a minute ago with a hook in the porch. Then I realised the only full height wall is a glass window."
so remove it out the shed where its at least not on display - to putting it in full view in a window like an advert to steal it ?
Posted : 16/02/2016 11:22 am
Ha no sorry, the window is only internal. The outer is all brick. It's between the porch and the house.
I didn't explain it very well.
Posted : 16/02/2016 11:26 am
Got three bikes hanging by the front wheel in a utility room - probably about 6 foot long and 3 to 4 foot wide.
Used the Halfords BikeHut wall hangers. Bars on the 2 MTBs are twisted in line with the frame. Looks a bit like Frankenstein's photo above for the bike spacing. Wall mounts are at slightly different heights so that cables and stuff don't tangle.
Works well, got to watch pedals when taking them out. I have considered taking the pedals off before storing but being careful is more convenient than putting pedals back on before each ride.
Posted : 16/02/2016 11:28 am
I used to keep mine in the halls of residence as a student by taking the pedal off the non drive side and sliding it under the bed. The beds were quite tall frames with thin foam mattresses though.
Only other (not so sensible) option I can think up, is one I saw on pintrest. Use one of the ceiling suspended bike hooks on rope thingies, but install it at the top of the stairwell (as long as you have a full height staircase, not an airing cupboard or something above it). Would require a perfectly clean and dry bike every time though!
Posted : 16/02/2016 11:30 am
Divorce/Dump your Mrs, and just park it wherever the hell you like inside?
Posted : 16/02/2016 11:37 am
Quick question on insurance. It's a custom build but do insure against cost to build or an (as near) Orange pre specced option?
Posted : 16/02/2016 11:38 am
It sounds like whatever you do possibly achieve in this porch wont give the right results and the missus will make you move them anyway.
Im quite lucky - we live in a very small house but there is a walk in cupboard upstairs where I store all the bikes and gear. The other half wants them in the shed, I completly refuse this idea.
Anyway, I suggest the loft. Get some boards (B&Q do them cheap) board it out, or even just half of it, get a loft ladder and job done. Everyone is happy then. Bikes are safe and not in everyones way downstairs. Wheels off, carry them up.
Yes it'll be a bit of a faff dragging them in and out when you want them, but its that or move house 🙂 Or the shed where at some point they will be stolen. If we didnt have our cupboard, I'd be using the loft.
Posted : 16/02/2016 11:49 am
I have a small spare bedroom with a single guest bed. The bike goes on that, wrapped in a sort of bag I made from a tarp (basic wrap-around design with some bits of velcro to hold it in place). It could theoretically go in their covered in mud, but it's a good motivation to clean the bike after a ride.
The space on the bed would otherwise be unused so not really a problem. Though we do keep loosely folded sleeping bags on it as well - these go on top of the bike, which helps hide it even more.
mine are kept on the balcony or shared attic space. The bikes in the balcony are fixed to the wall with a hook across the stem, with pedals off to help pack them closer together. I try to avoid hooking them through the front wheel as the tyres are too big to fit around the hook. Bars are rotated, too.
If i owned my own place, I'd build something like below, for the entrance/ hallway. It would fit only one bike, probably the most often used mtb.
Posted : 16/02/2016 11:54 am
I use £1.50 ladder hook from wilkinsons into the wall and hooked round the front wheel.
Mate of mine does the same but has a length of guttering screwed to the wall under the wheels to stop mess.
Posted : 16/02/2016 12:07 pm
Well my insurer, The Post Office, won't insure it anyway 🙁
Posted : 16/02/2016 12:15 pm
I hung my TT bike up in the "study" Hangs via the NDS pedal behind the door above a bookcase and the desk - only comes down for 10 or so events a year.
Posted : 16/02/2016 2:56 pm
My 2 are in the lounge leaning against the wall.
Yes I do live on my own.
Posted : 16/02/2016 3:24 pm
I want to build an outbuilding instead of a shed.
Our shed is old and needs replacing really, could I put up a concrete/brick structure instead without needing planning permission?
Posted : 16/02/2016 3:28 pm
Surely your best option as a concrete slab in the garden with an Asguard on top isn't it? You could at least then take the asguard with you when you move.
Posted : 16/02/2016 4:16 pm
to the well versed thief an asgard screams "bikes - probably pricy"
Posted : 16/02/2016 4:45 pm
I've decided divorce is the only option!
Posted : 16/02/2016 5:04 pm
Really? I would think "gardening equipment" would be the most likely
Posted : 16/02/2016 5:22 pm
When we bought our house, the agreement was the wife would get the garden to do what she wanted, and I'd get the celler..
It's nearly done, but it'll be my bike store.
Posted : 16/02/2016 8:30 pm
The pedal hangers as in Trailrat's pic above, are very good. There's a few out there, mine are branded Point.
Posted : 16/02/2016 9:45 pm
I live in a fairly generous Victorian terrace house, but struggle with storage space for our family of four's bike collection. Our 6x4 shed is full!
We do, however, have a dormer loft conversion; with a big void above the flight of stairs from second to third floor. This was my solution to the question of where to store a tagalong for the kids:
I use a [url= http://cycloc.com/cycloc-features-Endo.html ]Cycloc Endo[/url], which has securely held the considerable weight of the above Trek Mountain Train for 2 years. I'll be adding another soon, for my new road bike.
Posted : 16/02/2016 10:08 pm
2 hang in the kitchen and the other two are kept warm in the livingroom.. 🙂
[url= https://farm2.staticflickr.com/1457/24003611340_fa383f8287_c.jp g" target="_blank">https://farm2.staticflickr.com/1457/24003611340_fa383f8287_c.jp g"/> [/img][/url][url= https://flic.kr/p/Cz7MnW ]10th Jan; Sunday Cycle 061[/url] by [url= https://www.flickr.com/photos/coastkid71/ ]Bruce[/url], on Flickr
Posted : 16/02/2016 10:15 pm
And then there's the tandem, which conveniently hangs from its stoker bar and cantilevers off the pedals:
Posted : 16/02/2016 10:42 pm
[img] ?v=1323678134[/img]
Something like that? Victorian style airer pulleys can be had cheaply.
Posted : 16/02/2016 11:56 pm
