Sticky Piston M585 ...
[Closed] Sticky Piston M585 LX Brakes
Hi,
I have a M585 (Shimano) caliper, linked to dual control lx brake levers (from 07). The caliper on my front break is sticky on one side only, meaning I have little breaking power and keep glazing the pads off as the disc just rubs rather than bites.
I thought it was contaminated pads but the piton is very slow to move.
Any fixes? I have tried a bit of 3 in 1 oil round the seal, as I had some to hand, but not sure what the best course of action is? Have also tried pumping the brake whilst holding in the good piston.
Posted : 27/05/2012 11:18 am
It may be to pop the piston right out, and wipe it and the calliper seal clean. Messy and need to rebleed, but ultimately could be quicker
Posted : 27/05/2012 12:09 pm
^^ probably the easiest route. And just lube with mineral oil brake fluid - nothing else
Posted : 27/05/2012 12:17 pm
Plenty of advice here on sticking pistons in previous threads, try a search if you haven't already, should help you I think.
Thanks for the advice above. I did try searching with limited success and have gone for the advice offered above by andyl re: mineral oil, as I don't have time to complete srtip the brake at the moment. Will look as a more thorough job if it continues to be a problem.
Replaced pads too and they seem to bit more now, but before I put the pads back in the piston still seemed to be a bit reluctant to ease itself out. Will see how it goes when I go riding in the Lake District next.
Posted : 28/05/2012 7:44 am
I know its a ball ache (especially the first time you do it) but it does suggest you've got crap in the seals, sooner rather than later could be a good idea...
Posted : 28/05/2012 7:48 am
good luck and if you sort it, please post what you did!
still stuck with mine: http://singletrackworld.com/forum/topic/sticky-pistons-again
tho must admit i haven't tried the baby oil ๐Ÿ™‚
Posted : 28/05/2012 7:52 am
Might be of use if you've not seen these threads, might not if you have!
[url= http://singletrackworld.com/forum/search.php?search=sticking+piston&advanced=1&exact=1&posts=1&highlight=1&users=0&located=0&forums []=1&maxcount=100&age=366&direction=0&sort=date&order=0][/url]
EDIT
I tried to link the advance search in the bike forum for 1 year but it's not showing.
Posted : 28/05/2012 8:40 am
